ArcGIS.Desktop.Mapping Namespace / DefinitionQuery Class / DefinitionQuery Constructor / DefinitionQuery Constructor()
Example
    Creates a new instance of the DefinitionQuery object.
    Syntax
    Public Function New()
    public DefinitionQuery()
    Example
    Querying a feature layer with a spatial filter
        var layers = map.GetLayersAsFlattenedList().OfType<FeatureLayer>();
        var layerToQuery = layers.FirstOrDefault(f => f.Name == "USNationalParks");
        if (layerToQuery == null) return;
        string whereClause = "RecreationVisitsTotal > 1000000"; //More than million visitors a year
        var spatialDefnLayer = layers.FirstOrDefault(f => f.Name == "AllUSStates");
        if (spatialDefnLayer == null) return;
        try
            if (MapView.Active == null) return;
            //Note: needs to be called on the MCT
            // Set the spatial filter geometry
            //Get the geometry from the selected features in the feature layer
            var spatialClauseGeom = spatialDefnLayer.GetFeatureOutline(MapView.Active, FeatureOutlineType.Selected);
            //Create the definition query
            DefinitionQuery definitionQuery = new DefinitionQuery
                WhereClause = whereClause,
                Name = $"{layerToQuery.Name}"
            //Setting the spatial filter to the Definition Query
            if (definitionQuery.CanSetFilterGeometry(spatialClauseGeom))
                definitionQuery.SetFilterGeometry(spatialClauseGeom);
            layerToQuery.InsertDefinitionQuery(definitionQuery);
            layerToQuery.SetActiveDefinitionQuery(definitionQuery.Name);
        catch (Exception ex)
            System.Diagnostics.Debug.WriteLine($"Error querying feature layer: {ex.Message}");
    Apply A Definition Query Filter to a Feature Layer
        var us_parks = map.GetLayersAsFlattenedList()
      .OfType<FeatureLayer>().First(l => l.Name == "USNationalParks");
        var def_query = new DefinitionQuery("CaliforniaParks",
                          "STATE_ABBR = 'CA'");
        us_parks.InsertDefinitionQuery(def_query);
        us_parks.SetDefinitionQuery("STATE_ABBR = 'CA'");
        //Set it active
        us_parks.SetActiveDefinitionQuery(def_query.Name);
        //or....also - set it active when it is inserted
        //us_parks.InsertDefinitionQuery(def_query, true);
    Apply A Definition Query Filter With a Filter Geometry to a Feature Layer
        var greatLakes = map.GetLayersAsFlattenedList()
              .OfType<FeatureLayer>().First(l => l.Name == "Great Lakes");
        var usa_states = map.GetLayersAsFlattenedList()
        .OfType<FeatureLayer>().First(l => l.Name == "US_States");
        //name must be unique
        var def_query = new DefinitionQuery("GreatLakes",
                              "NAME in ('Huron','Michigan','Erie')");
        //create a filter geometry - in this example we will use the outline geometry
        //of all visible features from a us states layer...the filter geometry will be
        //intersected with the layer feature geometry when added to the def query
        var filter_geom = usa_states.GetFeatureOutline(mapView, FeatureOutlineType.Visible);
        //other options...
        //var filter_geom = usa_states.GetFeatureOutline(mapView, FeatureOutlineType.All);
        //var filter_geom = usa_states.GetFeatureOutline(mapView, FeatureOutlineType.Selected);
        //Geometry must have a valid SR and be point, multi-point, line, or poly
        if (def_query.CanSetFilterGeometry(filter_geom))
            def_query.SetFilterGeometry(filter_geom);
        //Apply the def query
        greatLakes.InsertDefinitionQuery(def_query);
        //Set it active
        greatLakes.SetActiveDefinitionQuery(def_query.Name);
        //greatLakes.InsertDefinitionQuery(def_query, true);
    Create a stream layer with a definition query
      // Note: call within QueuedTask.Run()
        //Must be on the QueuedTask
        var url = "https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
        var lyrCreateParam = new FeatureLayerCreationParams(new Uri(url))
          IsVisible = true,
          DefinitionQuery = new DefinitionQuery(whereClause: "RWY = '29L'", name: "Runway")
        streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(lyrCreateParam, map);
    Requirements
