public DefinitionQuery DefinitionQuery {get; set;}
Public Property DefinitionQuery As DefinitionQuery
var flyrCreatnParam = new FeatureLayerCreationParams(new Uri(@"c:\data\world.gdb\cities"))
Name = "World Cities",
IsVisible = false,
MinimumScale = 1000000,
MaximumScale = 5000,
DefinitionQuery = new DefinitionQuery(whereClause: "Population > 100000", name: "More than 100k"),
RendererDefinition = new SimpleRendererDefinition()
SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(
CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
var featureLayerWithParams = await QueuedTask.Run(() =>
LayerFactory.Instance.CreateLayer<FeatureLayer>(flyrCreatnParam, map));
//The catalog path of the feature layer to add to the map
var featureClassUriDefinition = new Uri(@"C:\Data\Admin\AdminData.gdb\USA\cities");
//Define the Feature Layer's parameters.
var layerParamsQueryDefn = new FeatureLayerCreationParams(featureClassUriDefinition)
IsVisible = true,
DefinitionQuery = new DefinitionQuery(whereClause: "STATE_NAME = 'California'", name: "CACities")
//Create the layer with the feature layer parameters and add it to the active map
var createdFCWithQueryDefn = await QueuedTask.Run(() =>
LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParamsQueryDefn, map));
// get a feature class that is selected in the catalog pane
Item item = Project.GetCatalogPane().SelectedItems.FirstOrDefault();
var uriShp = new Uri(@"c:\data\roads.shp");
var lcpShp = new FeatureLayerCreationParams(uriShp);
lcpShp.Name = "Roads";
lcpShp.IsVisible = false;
lcpShp.DefinitionQuery = new DefinitionQuery("shpQuery", "OBJECTID > 10");
var lcpItem = new FeatureLayerCreationParams(item);
lcpItem.Name = "Census Polygons";
lcpItem.IsVisible = true;
// list contains a Uri data source and an Item data source
// LayerFactory.Instance.CreateLayers will throw an ArgumentException
var lcps = new List<FeatureLayerCreationParams>();
lcps.Add(lcpShp);
lcps.Add(lcpItem);
var blkParams = new BulkLayerCreationParams(lcps);
// LayerFactory.Instance.CreateLayers will thrown an ArgumentException
// because the LayerCreationParams are created using different
// types of data sources (1 Uri and 1 Item)
var layers = await QueuedTask.Run(() => LayerFactory.Instance.CreateLayers(blkParams, map));
var uriSde = new Uri(@"c:\MyDataConnections\MySDE.sde\Census");
var uri = new Uri(@"http://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/FeatureServer/0");
var lcpSde = new FeatureLayerCreationParams(uriSde);
lcpSde.Name = "Census Polygons";
lcpSde.IsVisible = true;
var lcpService = new FeatureLayerCreationParams(uri);
lcpService.Name = "Shelters";
lcpService.IsVisible = true;
// set some renderer here ...
//lcpService.RendererDefinition = ...
lcps.Add(lcpShp);
lcps.Add(lcpSde);
lcps.Add(lcpService);
// set the positioning on the BulkLayerCreationParams
blkParams.MapMemberPosition = MapMemberPosition.Index;
blkParams.MapMemberIndex = 0;
lcps.Add(lcpShp);
lcps.Add(lcpSde);
// set the rollback behavior
// - rollback if one or more layers cannot be created due to an invalid data source
blkParams.RollbackBehavior = LayerCreationRollbackBehavior.RollbackOnMissingLayers;
var url = "https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
var lyrCreateParam = new FeatureLayerCreationParams(new Uri(url))
IsVisible = true,
DefinitionQuery = new DefinitionQuery(whereClause: "RWY = '29L'", name: "Runway")
streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(lyrCreateParam, map);
