ArcGIS.Desktop.Mapping Namespace / ImageServiceLayer Class / InsertDefinitionQuery Method
A DefinitionQuery object.
A boolean to indicate it should be the active definition query.
    InsertDefinitionQuery Method (ImageServiceLayer)
    Inserts a DefinitionQuery. If makeActive is true, makes it the active definition query. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void InsertDefinitionQuery(
       DefinitionQuery definitionQuery,
       bool makeActive
    Public Sub InsertDefinitionQuery( _
       ByVal definitionQuery As DefinitionQuery, _
       Optional ByVal makeActive As Boolean _
    Parameters
    definitionQuery
    makeActive
    Exceptions
    ExceptionDescription
    A definition query with the same name already exists in the list.
    Where clause of the definitionQuery is empty.
    Remarks
    The DefinitionQuery.Name of the definitionQuery cannot already exist in the list of DefinitionQueries. When Name is empty, an automatically generated name gets assigned.The WhereClause cannot be empty.
    Requirements
