ArcGIS.Desktop.Mapping Namespace / Map Class / ClearElevationSurfaceLayers Method
Example
    Will remove all elevation surfaces from the map with the exception of Ground. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void ClearElevationSurfaceLayers()
    Public Sub ClearElevationSurfaceLayers()
    Exceptions
    ExceptionDescription
    Remarks
    The Ground surface cannot be removed.
    On success, an undo-able operation is added to the current operation manager undo stack
    Example
    Remove elevation surface layers
      //Ground will not be removed
      map.ClearElevationSurfaceLayers();
      ElevationSurfaceLayer surfaceLayer = map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "Surface2");
      //Cannot remove ground
      map.RemoveLayer(surfaceLayer);
      map.RemoveLayers(map.GetElevationSurfaceLayers());
    Requirements
