ArcGIS.Desktop.Mapping Namespace / SubtypeGroupLayer Class / SetActiveDefinitionQuery Method
The name of the query definition to set as active.
    SetActiveDefinitionQuery Method (SubtypeGroupLayer)
    Sets the definition query matching the specified queryName to be the active definition query. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetActiveDefinitionQuery(
       string queryName
    Public Sub SetActiveDefinitionQuery( _
       ByVal queryName As String _
    Parameters
    queryName
    Exceptions
    ExceptionDescription
    There are no query definitions.
    The specified queryName doesn't match any items in the query definition collection.
    Remarks
    If the queryName is null, then the active query definition is removed and the layer no longer has an active definition query.
    Requirements
