ArcGIS.Core.Events Namespace / RegisteredPresentationEvent<TSubscriptionParam,TPayload> Class / Contains Method / Contains(SubscriptionToken) Method
The SubscriptionToken returned by EventBase while subscribing to the event.
    Returns true if there is a subscriber matching SubscriptionToken.
    Syntax
    protected internal bool Contains(
       SubscriptionToken token
    Protected Friend Overloads Function Contains( _
       ByVal token As SubscriptionToken _
    ) As Boolean
    Parameters
    token
    Return Value
    true if there is a SubscriptionToken that matches; otherwise false.
    Requirements
