ArcGIS.Core.Geometry Namespace / AngularUnit Class / ConvertTo(Double,AngularUnit) Method
Angle in the units of this instance.
Unit to convert to.
Example
    Converts the angle to the provided angular unit.
    Syntax
    Public Function ConvertTo( _
       ByVal inAngle As Double, _
       ByVal outUnit As AngularUnit _
    ) As Double
    public double ConvertTo(
       double inAngle,
       AngularUnit outUnit
    Parameters
    inAngle
    outUnit
    Unit to convert to.
    Return Value
    Angle converted to the specified unit.
    Exceptions
    ExceptionDescription
    The outUnit is null.
    Example
    AngularUnit - Create an AngularUnit with a factory code
      try
        // create a Grad unit
        var grad = AngularUnit.CreateAngularUnit(9105);
        string unitName = grad.Name;                        // Grad
        double conversionFactor = grad.ConversionFactor;    // 0.015708
        double radiansPerUnit = grad.RadiansPerUnit;
        int factoryCode = grad.FactoryCode;                 // 9105
        // convert 10 grads to degrees
        double val = grad.ConvertTo(10, AngularUnit.Degrees);
        // convert 10 radians to grads
        val = grad.ConvertFromRadians(10);
      catch (ArgumentException)
        // ArgumentException will be thrown by CreateAngularUnit in
        // the following scenarios:
        // - if the factory code used is a non-angular factory code
        //   (i.e. it corresponds to square meters which is an area unit code)
        // - if the factory code used is invalid
        //   (i.e. it is negative or doesn't correspond to any factory code)
    AngularUnit - Create a Custom AngularUnit
      // custom unit - 3 radians per unit
      var myAngularUnit = AngularUnit.CreateAngularUnit("myCustomAngularUnit", 3);
      string Name = myAngularUnit.Name;                   // myCustomAngularUnit
      double Factor = myAngularUnit.ConversionFactor;     // 3
      int Code = myAngularUnit.FactoryCode;               // 0 because it is a custom angular unit
      double radiansUnit = myAngularUnit.RadiansPerUnit;  // 3
      // convert 10 degrees to my unit
      double converted = AngularUnit.Degrees.ConvertTo(10, myAngularUnit);
      // convert it back to degrees
      converted = myAngularUnit.ConvertTo(converted, AngularUnit.Degrees);
      // convert 1 radian into my angular units
      converted = myAngularUnit.ConvertFromRadians(1);
      // get the wkt
      string wkt = myAngularUnit.Wkt;
      // create an angular unit from this wkt
      var anotherAngularUnit = AngularUnit.CreateAngularUnit(wkt);
      // anotherAngularUnit.ConversionFactor = 3
      // anotherAngularUnit.FactoryCode = 0
      // anotherAngularUnit.RadiansPerUnit = 3
    Requirements
