ArcGIS.Core.Geometry Namespace / AngularUnit Class / ConvertToRadians Method
Angle in the units of this instance.
Example
    Converts the angle to radians.
    Syntax
    Public Function ConvertToRadians( _
       ByVal angle As Double _
    ) As Double
    public double ConvertToRadians(
       double angle
    Parameters
    angle
    Return Value
    Angle converted to radians.
    Example
    AngularUnit - Convert between degrees and radians
      // convert 45 degrees to radians
      double radians = AngularUnit.Degrees.ConvertToRadians(45);
      // convert PI to degrees
      double degrees = AngularUnit.Degrees.ConvertFromRadians(Math.PI);
    Requirements
