ArcGIS.Core.Geometry Namespace / AngularUnit Class / CreateAngularUnit Method / CreateAngularUnit(Int32) Method
The angular unit factory code.
Example
    Convenience method to quickly create a AngularUnit instance using a factory code.
    Syntax
    Public Overloads Shared Function CreateAngularUnit( _
       ByVal factoryCode As Integer _
    ) As AngularUnit
    public static AngularUnit CreateAngularUnit(
       int factoryCode
    Parameters
    factoryCode
    Return Value
    Exceptions
    ExceptionDescription
    The factoryCode is not a valid angular unit code.
    Remarks
    The available angular units of measure.
    Factory Code Unit Name
    9101 Radian
    9102 Degree
    9103 Arc-minute
    9104 Arc-second
    9105 Grad
    9106 Gon
    9109 Microradian
    9112 Centesimal arc-minute
    9113 Centesimal arc-second
    9114 Mil
    909003 DD (Decimal Degree)
    909004 DMS (Degree Minute Second)
    909005 DDM (Degree Decimal Minute)
    Example
    AngularUnit - Create an AngularUnit with a factory code
      try
        // create a Grad unit
        var grad = AngularUnit.CreateAngularUnit(9105);
        string unitName = grad.Name;                        // Grad
        double conversionFactor = grad.ConversionFactor;    // 0.015708
        double radiansPerUnit = grad.RadiansPerUnit;
        int factoryCode = grad.FactoryCode;                 // 9105
        // convert 10 grads to degrees
        double val = grad.ConvertTo(10, AngularUnit.Degrees);
        // convert 10 radians to grads
        val = grad.ConvertFromRadians(10);
      catch (ArgumentException)
        // ArgumentException will be thrown by CreateAngularUnit in
        // the following scenarios:
        // - if the factory code used is a non-angular factory code
        //   (i.e. it corresponds to square meters which is an area unit code)
        // - if the factory code used is invalid
        //   (i.e. it is negative or doesn't correspond to any factory code)
    Requirements
