try
// create a Grad unit
var grad = AngularUnit.CreateAngularUnit(9105);
string unitName = grad.Name; // Grad
double conversionFactor = grad.ConversionFactor; // 0.015708
double radiansPerUnit = grad.RadiansPerUnit;
int factoryCode = grad.FactoryCode; // 9105
// convert 10 grads to degrees
double val = grad.ConvertTo(10, AngularUnit.Degrees);
// convert 10 radians to grads
val = grad.ConvertFromRadians(10);
catch (ArgumentException)
// ArgumentException will be thrown by CreateAngularUnit in
// the following scenarios:
// - if the factory code used is a non-angular factory code
// (i.e. it corresponds to square meters which is an area unit code)
// - if the factory code used is invalid
// (i.e. it is negative or doesn't correspond to any factory code)
// custom unit - 3 radians per unit
var myAngularUnit = AngularUnit.CreateAngularUnit("myCustomAngularUnit", 3);
string Name = myAngularUnit.Name; // myCustomAngularUnit
double Factor = myAngularUnit.ConversionFactor; // 3
int Code = myAngularUnit.FactoryCode; // 0 because it is a custom angular unit
double radiansUnit = myAngularUnit.RadiansPerUnit; // 3
// convert 10 degrees to my unit
double converted = AngularUnit.Degrees.ConvertTo(10, myAngularUnit);
// convert it back to degrees
converted = myAngularUnit.ConvertTo(converted, AngularUnit.Degrees);
// convert 1 radian into my angular units
converted = myAngularUnit.ConvertFromRadians(1);
// get the wkt
string wkt = myAngularUnit.Wkt;
// create an angular unit from this wkt
var anotherAngularUnit = AngularUnit.CreateAngularUnit(wkt);
// anotherAngularUnit.ConversionFactor = 3
// anotherAngularUnit.FactoryCode = 0
// anotherAngularUnit.RadiansPerUnit = 3
