ArcGIS.Core.Geometry Namespace / AreaUnit Class
    AreaUnit Class Properties
    For a list of all members of this type, see AreaUnit members.
    Public Properties
     NameDescription
    Public Propertystatic (Shared in Visual Basic)Gets an area unit object representing area in US acres (Factory Code = 109403).
    Public Propertystatic (Shared in Visual Basic)Gets an area unit object representing area in ares (Factory Code = 109463).
    Public Property Gets the conversion factor of the unit. (Inherited from ArcGIS.Core.Geometry.Unit)
    Public PropertyGets the well-known ID of the unit. If the unit is a custom unit, then the factory code will be 0. (Inherited from ArcGIS.Core.Geometry.Unit)
    Public Propertystatic (Shared in Visual Basic)Gets an area unit object representing area in hectares (Factory Code = 109401).
    Public PropertyGets the name of the unit. (Inherited from ArcGIS.Core.Geometry.Unit)
    Public Propertystatic (Shared in Visual Basic)Gets an area unit object representing area in square centimeters (Factory Code = 109451).
    Public Propertystatic (Shared in Visual Basic)Gets an area unit object representing area in square decimeters (Factory Code = 109450).
    Public Propertystatic (Shared in Visual Basic)Gets an area unit object representing area in square feet (Factory Code = 109405).
    Public Propertystatic (Shared in Visual Basic)Gets an area unit object representing area in square inches (Factory Code = 109453).
    Public Propertystatic (Shared in Visual Basic)Gets an area unit object representing area in square kilometers (Factory Code = 109414).
    Public Propertystatic (Shared in Visual Basic)Gets an area unit object representing area in square meters (Factory Code = 109404).
    Public Property Gets the square meters per unit.
    Public Propertystatic (Shared in Visual Basic)Gets an area unit object representing area in square miles (Factory Code = 109439).
    Public Propertystatic (Shared in Visual Basic)Gets an area unit object representing area in square millimeters (Factory Code = 109452).
    Public Propertystatic (Shared in Visual Basic)Gets an area unit object representing area in square yards (Factory Code = 109442).
    Public PropertyGets the type of unit. (Inherited from ArcGIS.Core.Geometry.Unit)
    Public Property Gets the well-known text of the unit. (Inherited from ArcGIS.Core.Geometry.Unit)
    Top
