ArcGIS.Core.Geometry Namespace / CompositeGeographicTransformation Class / Create Method / Create(String,Boolean) Method
The well-known text of the geographic transformation to be created and added.
(Optional) Default is true. If false, the created geographic transformation is inverted.
Example
    Creates a new GeographicTransformation instance with the given well-known text and direction, and adds it to a new CompositeGeographicTransformation instance.
    Syntax
    Public Overloads Shared Function Create( _
       ByVal wkt As String, _
       Optional ByVal transformForward As Boolean _
    ) As CompositeGeographicTransformation
    Parameters
    wkt
    transformForward
    Return Value
    Example
    Create Composite Geographic Transformation
      // Create singleton from wkid
      CompositeGeographicTransformation cgt =
          ArcGIS.Core.Geometry.CompositeGeographicTransformation.Create(108272);
      int count = cgt.Count;    // count = 1
      IList<GeographicTransformation> gts = cgt.Transformations
                                      as IList<GeographicTransformation>;
      gts.Add(ArcGIS.Core.Geometry.GeographicTransformation.Create(1437, false));
      count = cgt.Count;        // count = 2
      // create from an enumeration
      CompositeGeographicTransformation another_cgt =
                    ArcGIS.Core.Geometry.CompositeGeographicTransformation.Create(gts);
      GeographicTransformation gt0 = another_cgt[0];
      GeographicTransformation gt1 = another_cgt[1];
      // get the inverse
      CompositeGeographicTransformation inversed_cgt = another_cgt.GetInverse() as CompositeGeographicTransformation;
      // inversed_cgt[0] is same as gt1
      // inversed_cgt[1] is same as gt0
      var wkt = gt0.Wkt;
      // create from string
      CompositeGeographicTransformation third_cgt =
         ArcGIS.Core.Geometry.CompositeGeographicTransformation.Create(wkt, gt0.IsForward);
      count = third_cgt.Count;        // count = 1
      // create from josn
      string json = cgt.ToJson();
      CompositeGeographicTransformation joson_cgt =
        DatumTransformation.CreateFromJson(json) as CompositeGeographicTransformation;
    Requirements
