ArcGIS.Core.Geometry Namespace / CompositeGeographicTransformation Class / Create Method / Create(IEnumerable<GeographicTransformation>) Method
The list of geographic transformations to add to a CompositeGeographicTransformation.
Example
    Creates a new CompositeGeographicTransformation instance that contains the list of GeographicTransformation instances.
    Syntax
    Parameters
    geoTransformations
    Return Value
    A new CompositeGeographicTransformation that contains the list of GeographicTransformations.
    Example
    Create Composite Geographic Transformation
      // Create singleton from wkid
      CompositeGeographicTransformation cgt =
          ArcGIS.Core.Geometry.CompositeGeographicTransformation.Create(108272);
      int count = cgt.Count;    // count = 1
      IList<GeographicTransformation> gts = cgt.Transformations
                                      as IList<GeographicTransformation>;
      gts.Add(ArcGIS.Core.Geometry.GeographicTransformation.Create(1437, false));
      count = cgt.Count;        // count = 2
      // create from an enumeration
      CompositeGeographicTransformation another_cgt =
                    ArcGIS.Core.Geometry.CompositeGeographicTransformation.Create(gts);
      GeographicTransformation gt0 = another_cgt[0];
      GeographicTransformation gt1 = another_cgt[1];
      // get the inverse
      CompositeGeographicTransformation inversed_cgt = another_cgt.GetInverse() as CompositeGeographicTransformation;
      // inversed_cgt[0] is same as gt1
      // inversed_cgt[1] is same as gt0
      var wkt = gt0.Wkt;
      // create from string
      CompositeGeographicTransformation third_cgt =
         ArcGIS.Core.Geometry.CompositeGeographicTransformation.Create(wkt, gt0.IsForward);
      count = third_cgt.Count;        // count = 1
      // create from josn
      string json = cgt.ToJson();
      CompositeGeographicTransformation joson_cgt =
        DatumTransformation.CreateFromJson(json) as CompositeGeographicTransformation;
    Requirements
