ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Extend Method
The polyline to be extended.
The polyline to extend to.
The type of extend operation to perform.
Example
    Extend Method (GeometryEngine)
    Performs the extend operation on a polyline using a polyline as the extender. The output polyline will have the first and last segment of each part extended to the extender if the segments can be interpolated to intersect the extender. In the case that the segments can be extended to multiple segments of the extender, the shortest extension is chosen. Only end points for parts that are not shared by the end points of other parts will be extended. If the polyline cannot be extended by the input extender, then a null will be returned.
    Syntax
    Public Function Extend( _
       ByVal polyline As Polyline, _
       ByVal extender As Polyline, _
       ByVal extendFlags As ExtendFlags _
    ) As Polyline
    Parameters
    polyline
    extender
    extendFlags
    Return Value
    The extended polyline. If polyline or extender are empty, then null is returned.
    Exceptions
    ExceptionDescription
    Either polyline or extender or both are null.
    Incompatible spatial references between the input geometries.
    Throws InvalidOperationException if both ExtendFlags.NoEndAttributes and ExtendFlags.KeepEndAttributes flags are sent together.
    Remarks
    Equivalent to IConstructCurve.ConstructExtended
    Example
    Extend a polyline
      // build a polyline
      polyline = PolylineBuilderEx.CreatePolyline(
        MapPointBuilderEx.CreateMapPoint(1, 1, 10, 20),
        MapPointBuilderEx.CreateMapPoint(0, 0, 10, 20),
        MapPointBuilderEx.CreateMapPoint(1, -1, 10, 20)
      // build the extender line
      var extender = PolylineBuilderEx.CreatePolyline(
        MapPointBuilderEx.CreateMapPoint(2, 2),
        MapPointBuilderEx.CreateMapPoint(2, -2),
      // extend
      var result = GeometryEngine.Instance.Extend(polyline, extender, ExtendFlags.KeepEndAttributes);
      Polyline extendedLine = result as Polyline;
      // result.Parts[0].Points[0] = 2, 2, 10, 20
      // result.parts[0].Points[1] = 1, 1, 10, 20
      // result.Parts[0].Points[2] = 0, 0, 10, 20
      // result.Parts[0].Points[3] = 1, -1, 10, 20
      // result.Parts[0].Points[4] = 2, -2, 10, 20
      // change the flags
      result = GeometryEngine.Instance.Extend(polyline, extender, ExtendFlags.NoEndAttributes);
      // result.Parts[0].Points[0] = 2, 2, 0
      // result.Parts[0].Points[4] = 2, -2, 0
      // extend
      result = GeometryEngine.Instance.Extend(polyline, extender, ExtendFlags.KeepEndAttributes | ExtendFlags.NoExtendAtTo);
      // extend with no intersection
        MapPointBuilderEx.CreateMapPoint(1, 1),
        MapPointBuilderEx.CreateMapPoint(3, 1)
        MapPointBuilderEx.CreateMapPoint(1, 4),
        MapPointBuilderEx.CreateMapPoint(3, 4)
      result = GeometryEngine.Instance.Extend(polyline, extender, ExtendFlags.Default);
      // result = null
      // Use the result ...
    Requirements
