ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Length3D Method
The input geometry.
Example
    Length3D Method (GeometryEngine)
    Gets the 3D length for a specified geometry.
    Syntax
    Public Function Length3D( _
       ByVal geometry As Geometry _
    ) As Double
    public double Length3D(
       Geometry geometry
    Parameters
    geometry
    The input geometry.
    Return Value
    The calculated length in the same units as the geometry's spatial reference unit. If the geometry is empty, then zero is returned.
    Exceptions
    ExceptionDescription
    Geometry is null.
    The method is not implemented for GeometryBag or Multipatch.
    The geometry is not Z-Aware.
    Cannot do 3D operations on curve segments.
    Geometry is not a polyline or polygon.
    Remarks
    The geometry must be Z-Aware or else an exception is thrown.
    Example
    Determine Length, Length3D of line
      MapPoint c1 = MapPointBuilderEx.CreateMapPoint(1, 2, 3);
      MapPoint c2 = MapPointBuilderEx.CreateMapPoint(4, 2, 4);
      // line segment
      LineSegment line = LineBuilderEx.CreateLineSegment(c1, c2);
      double len = line.Length;     // = 3
      double len3D = line.Length3D;   // = Math.Sqrt(10)
      // polyline
      Polyline p = PolylineBuilderEx.CreatePolyline(line);
      double p_len = p.Length;        // = len = 3
      double p_len3D = p.Length3D;    // = len3D = Math.Sqrt(10)
      double ge_len = GeometryEngine.Instance.Length(p);      // = p_len = len = 3
      double ge_len3d = GeometryEngine.Instance.Length3D(p);    // = p_len3D = len3D = Math.Sqrt(10)
    Requirements
