ArcGIS.Core.Geometry Namespace / GeometryEngine Class / ProjectEx Method
The geometry to be projected. The geometry spatial reference is ignored.
The projection transformation to use. The geometry is projected from the projTransformation.InputSpatialReference to the projTransformation.OutputSpatialReference
Example
    ProjectEx Method (GeometryEngine)
    Projects the given geometry to a new spatial reference.
    Syntax
    Parameters
    geometry
    projTransformation
    Return Value
    The projected geometry. If the input geometry is empty, then an empty geometry with the output spatial reference is returned.
    Exceptions
    ExceptionDescription
    Geometry is null.
    The method is not implemented for GeometryBag.
    Projection transformation is null.
    Example
    Create Projection Transformation
      // methods need to be on the MCT
      ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
        SpatialReference sr4267 = SpatialReferenceBuilder.CreateSpatialReference(4267);
        SpatialReference sr4326 = SpatialReferences.WGS84;
        SpatialReference sr3857 = SpatialReferences.WebMercator;
        // Create transformation from  4267 -> 3857
        ProjectionTransformation projTransFromSRs =
             ArcGIS.Core.Geometry.ProjectionTransformation.Create(sr4267, sr3857);
        // create an envelope
        Envelope env = EnvelopeBuilderEx.CreateEnvelope(
                   new Coordinate2D(2, 2), new Coordinate2D(3, 3), sr4267);
        // Project with one geo transform 4267 -> 3857
        Envelope projectedEnvEx = GeometryEngine.Instance.ProjectEx(
                                       env, projTransFromSRs) as Envelope;
        // Create inverse transformation, 3857 -> 4267
        ProjectionTransformation projTransFromSRsInverse =
            ArcGIS.Core.Geometry.ProjectionTransformation.Create(sr3857, sr4267);
        // Project the projected envelope back using the inverse transformation
        Envelope projectedEnvBack =
                 projectedEnvEx, projTransFromSRsInverse) as Envelope;
        bool isEqual = env.IsEqual(projectedEnvBack);
    Requirements
