ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Reshape Method
The geometry to be reshaped.
The reshaper.
Example
    Reshape Method (GeometryEngine)
    Reshapes a polygon or polyline with a single path polyline.
    Syntax
    Public Function Reshape( _
       ByVal multipart As Multipart, _
       ByVal reshaper As Polyline _
    ) As Multipart
    Parameters
    multipart
    reshaper
    The reshaper.
    Exceptions
    ExceptionDescription
    Either multipartor reshaperor both are null.
    Incompatible spatial references between the input geometries.
    The reshaper polyline must have exactly one part.
    Remarks
    The output geometry takes the shape of the input multipart where it first intersects the reshaper to the last intersection. The first and last intersection points of the reshaper are chosen closest to the end points of the reshaper in the case that multiple intersections are found. The output geometry may not be simple. If the geometry cannot be reshaped by the input reshaper, then null will be returned.
    Example
    Reshape a polygon
      List<Coordinate2D> polygon1Coords =
        new Coordinate2D(0, -11000),
      new Coordinate2D(1000, -11000),
      new Coordinate2D(1000, -12000),
      new Coordinate2D(0, -12000),
      // reshaper coordinates intersect the polygon
      List<Coordinate2D> reshaperCoords =
        new Coordinate2D(1500, -11800),
      new Coordinate2D(-2600, -11800)
      SpatialReference sr = SpatialReferenceBuilder.CreateSpatialReference(102010);
      Polygon polygon1 = PolygonBuilderEx.CreatePolygon(polygon1Coords, sr);
      Polyline reshaper = PolylineBuilderEx.CreatePolyline(reshaperCoords, sr);
      Polygon outPolygon = GeometryEngine.Instance.Reshape(polygon1, reshaper) as Polygon;
      // outPolygon.PartCount = 1
      ReadOnlySegmentCollection segments = outPolygon.Parts[0];
      // segments.Count = 4
      // outPolygon.PointCount = 5
      string json = GeometryEngine.Instance.ExportToJson(JsonExportFlags.JsonExportSkipCRS, outPolygon);
      // json = "{\"rings\":[[[0,-11800],[0,-11000],[1000,-11000],[1000,-11800],[0,-11800]]]}";
      // example where the Reshaper polyline doesn't intersect the input
      reshaperCoords.Clear();
      reshaperCoords.Add(new Coordinate2D(1000, 1000));
      reshaperCoords.Add(new Coordinate2D(2000, 1000));
      // outPolygon = null
    Requirements
