ArcGIS.Core.Geometry Namespace / LinearUnit Class / ConvertFromMeters Method
Distance to convert from in meters.
Example
    Converts a value in meters to the unit of this instance.
    Syntax
    public double ConvertFromMeters(
       double meters
    Public Function ConvertFromMeters( _
       ByVal meters As Double _
    ) As Double
    Parameters
    meters
    Return Value
    Distance converted from meters.
    Example
    LinearUnit - Convert between feet and meters
      // convert 10 feet to meters
      double metres = LinearUnit.Feet.ConvertToMeters(10);
      // convert 20 meters to feet
      double feet = LinearUnit.Feet.ConvertFromMeters(20.0);
    LinearUnit - Create a LinearUnit with a factory code
      try
        // create a british 1936 foot
        var britFoot = LinearUnit.CreateLinearUnit(9095);
        string unitName = britFoot.Name;                        //  "Foot_British_1936"
        double conversionFactor = britFoot.ConversionFactor;    // 0.3048007491
        double metersPerUnit = britFoot.MetersPerUnit;
        int factoryCode = britFoot.FactoryCode;                 // 9095
        // convert 10 british 1936 feet to centimeters
        double val = britFoot.ConvertTo(10, LinearUnit.Centimeters);
        // convert 10 m to british 1936 feet
        val = britFoot.ConvertFromMeters(10);
      catch (ArgumentException)
        // ArgumentException will be thrown by CreateLinearUnit
        // in the following scenarios:
        // - if the factory code used is a non-linear factory code
        //   (i.e. it corresponds to square meters which is an area unit code)
        // - if the factory code used is invalid
        //   (i.e. it is negative or doesn't correspond to any factory code)
    Requirements
