ArcGIS.Core.Geometry Namespace / LinearUnit Class / ConvertToMeters Method
Distance in the units of this instance.
Example
    Converts a value in the unit of this instance to meters.
    Syntax
    public double ConvertToMeters(
       double distance
    Public Function ConvertToMeters( _
       ByVal distance As Double _
    ) As Double
    Parameters
    distance
    Return Value
    Distance converted to meters.
    Example
    LinearUnit - Convert between feet and meters
      // convert 10 feet to meters
      double metres = LinearUnit.Feet.ConvertToMeters(10);
      // convert 20 meters to feet
      double feet = LinearUnit.Feet.ConvertFromMeters(20.0);
    LinearUnit - Convert between centimeters and millimeters
      // convert 11 centimeters to millimeters
      double mm = LinearUnit.Centimeters.ConvertTo(11, LinearUnit.Millimeters);
      // convert the result back to centimeters
      double cm = LinearUnit.Millimeters.ConvertTo(mm, LinearUnit.Centimeters);
      // convert the millimeter result back to meters
      double meters = LinearUnit.Millimeters.ConvertToMeters(mm);
    Requirements
