public static LinearUnit Centimeters {get;}
Public Shared ReadOnly Property Centimeters As LinearUnit
// convert 11 centimeters to millimeters
double mm = LinearUnit.Centimeters.ConvertTo(11, LinearUnit.Millimeters);
// convert the result back to centimeters
double cm = LinearUnit.Millimeters.ConvertTo(mm, LinearUnit.Centimeters);
// convert the millimeter result back to meters
double meters = LinearUnit.Millimeters.ConvertToMeters(mm);
try
// create a british 1936 foot
var britFoot = LinearUnit.CreateLinearUnit(9095);
string unitName = britFoot.Name; // "Foot_British_1936"
double conversionFactor = britFoot.ConversionFactor; // 0.3048007491
double metersPerUnit = britFoot.MetersPerUnit;
int factoryCode = britFoot.FactoryCode; // 9095
// convert 10 british 1936 feet to centimeters
double val = britFoot.ConvertTo(10, LinearUnit.Centimeters);
// convert 10 m to british 1936 feet
val = britFoot.ConvertFromMeters(10);
catch (ArgumentException)
// ArgumentException will be thrown by CreateLinearUnit
// in the following scenarios:
// - if the factory code used is a non-linear factory code
// (i.e. it corresponds to square meters which is an area unit code)
// - if the factory code used is invalid
// (i.e. it is negative or doesn't correspond to any factory code)
// create a custom linear unit - there are 0.33 meters per myLinearUnit
var myLinearUnit = LinearUnit.CreateLinearUnit("myCustomLinearUnit", 0.33);
string name = myLinearUnit.Name; // myCustomLinearUnit
double convFactor = myLinearUnit.ConversionFactor; // 0.33
int code = myLinearUnit.FactoryCode; // 0 for custom units
double metersUnit = myLinearUnit.MetersPerUnit; // 0.33
string toString = myLinearUnit.ToString(); // same as Name - myCustomLinearUnit
// convert 10 centimeters to myLinearUnit
double convertedVal = LinearUnit.Centimeters.ConvertTo(10, myLinearUnit);
// get the wkt
string lu_wkt = myLinearUnit.Wkt;
// create an angular unit from this wkt
var anotherLinearUnit = LinearUnit.CreateLinearUnit(lu_wkt);
// anotherLinearUnit.ConversionFactor = 0.33
// anotherLinearUnit.FactoryCode = 0
// anotherLinearUnit.MetersPerUnit = 0.33
