ArcGIS.Core.Geometry Namespace / Multipatch Class / PointCount Property
Example
    PointCount Property (Multipatch)
    Gets the count of all points in all parts for this instance.
    Syntax
    Public Overrides NotOverridable ReadOnly Property PointCount As Integer
    public override int PointCount {get;}
    Example
    Multipatch Properties
      int patchIndex = 0;
      // standard geometry properties
      bool hasZ = multipatch.HasZ;
      bool hasM = multipatch.HasM;
      bool hasID = multipatch.HasID;
      bool isEmpty = multipatch.IsEmpty;
      var sr = multipatch.SpatialReference;
      // number of patches (parts)
      int patchCount = multipatch.PartCount;
      // number of points
      int pointCount = multipatch.PointCount;
      // retrieve the points as MapPoints
      ReadOnlyPointCollection pointsMultipatch = multipatch.Points;
      // or as 3D Coordinates
      IReadOnlyList<Coordinate3D> coordinates = multipatch.Copy3DCoordinatesToList();
      // multipatch materials
      bool hasMaterials = multipatch.HasMaterials;
      int materialCount = multipatch.MaterialCount;
      // multipatch textures
      bool hasTextures = multipatch.HasTextures;
      int textureVertexCount = multipatch.TextureVertexCount;
      // normals
      bool hasNormals = multipatch.HasNormals;
      // properties for an individual patch (if multipatch.PartCount > 0)
      int patchPriority = multipatch.GetPatchPriority(patchIndex);
      PatchType patchType = multipatch.GetPatchType(patchIndex);
      // patch points
      int patchPointCount = multipatch.GetPatchPointCount(patchIndex);
      int pointStartIndex = multipatch.GetPatchStartPointIndex(patchIndex);
      // the patch Points are then the points in multipatch.Points from pointStartIndex to pointStartIndex + patchPointCount
      // if the multipatch has materials
      if (hasMaterials)
        // does the patch have a material?
        //   materialIndex = -1 if the patch does not have a material;
        //   0 <= materialIndex < materialCount if the patch does have materials
        int materialIndex = multipatch.GetPatchMaterialIndex(patchIndex);
        // properties for an individual material (if multipatch.MaterialCount > 0)
        var color = multipatch.GetMaterialColor(materialIndex);
        var edgeColor = multipatch.GetMaterialEdgeColor(materialIndex);
        var edgeWidth = multipatch.GetMaterialEdgeWidth(materialIndex);
        var shiness = multipatch.GetMaterialShininess(materialIndex);
        var percent = multipatch.GetMaterialTransparencyPercent(materialIndex);
        var cullBackFace = multipatch.IsMaterialCullBackFace(materialIndex);
        // texture properties
        bool isTextured = multipatch.IsMaterialTextured(materialIndex);
        if (isTextured)
          int columnCount = multipatch.GetMaterialTextureColumnCount(materialIndex);
          int rowCount = multipatch.GetMaterialTextureRowCount(materialIndex);
          int bpp = multipatch.GetMaterialTextureBytesPerPixel(materialIndex);
          TextureCompressionType compressionType = multipatch.GetMaterialTextureCompressionType(materialIndex);
          var texture = multipatch.GetMaterialTexture(materialIndex);
      // texture coordinates (if multipatch.HasTextures = true)
      if (hasTextures)
        int numPatchTexturePoints = multipatch.GetPatchTextureVertexCount(patchIndex);
        var coordinate2D = multipatch.GetPatchTextureCoordinate(patchIndex, 0);
        ICollection<Coordinate2D> textureCoordinates = new List<Coordinate2D>(numPatchTexturePoints);
        multipatch.GetPatchTextureCoordinates(patchIndex, ref textureCoordinates);
      // patch normals (if multipatch.HasNormals = true)
      if (hasNormals)
        //  number of normal coordinates = multipatch.GetPatchPointCount(patchIndex)
        Coordinate3D patchNormal = multipatch.GetPatchNormal(patchIndex, 0);
        ICollection<Coordinate3D> normalCoordinates = new List<Coordinate3D>(patchPointCount);
        multipatch.GetPatchNormals(patchIndex, ref normalCoordinates);
    Requirements
