ArcGIS.Core.Geometry Namespace / Polygon Class / IsEqual Method / IsEqual(Polygon) Method
A Polygon to test for equality.
    Compares two Polygon for equality. This will check that the SpatialReference, attribute awareness (HasZ, HasM, HasID), and the content of Multipart.Parts match. The order of parts must match too.
    Syntax
    Public Overloads Function IsEqual( _
       ByVal polygon As Polygon _
    ) As Boolean
    public bool IsEqual(
       Polygon polygon
    Parameters
    polygon
    Return Value
    Value to indicate if the two geometries are equal.
    Remarks
    To compare two geometries regardless of their point order you can use the Equals(Geometry,Geometry) method. GeometryEngine.Equals is a little more costly to compute.
    Requirements
