ArcGIS.Core.Geometry Namespace / ProjectionTransformation Class / Create Method
The spatial reference to project from. Cannot be unknown coordinate system.
The spatial reference to project to. Cannot be unknown coordinate system.
(Optional) The extent of the data that is being projected. Default is null. A null value or an empty envelope means the extent is the entire world.
Example
    Create Method (ProjectionTransformation)
    Creates a projection transformation from two spatial references and an extent of interest. Automatically selects a geographic transformation for the projection.
    Syntax
    Parameters
    inputSR
    outputSR
    extentOfInterest
    Return Value
    Example
    Create Projection Transformation
      // methods need to be on the MCT
      ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
        SpatialReference sr4267 = SpatialReferenceBuilder.CreateSpatialReference(4267);
        SpatialReference sr4326 = SpatialReferences.WGS84;
        SpatialReference sr3857 = SpatialReferences.WebMercator;
        // Create transformation from  4267 -> 3857
        ProjectionTransformation projTransFromSRs =
             ArcGIS.Core.Geometry.ProjectionTransformation.Create(sr4267, sr3857);
        // create an envelope
        Envelope env = EnvelopeBuilderEx.CreateEnvelope(
                   new Coordinate2D(2, 2), new Coordinate2D(3, 3), sr4267);
        // Project with one geo transform 4267 -> 3857
        Envelope projectedEnvEx = GeometryEngine.Instance.ProjectEx(
                                       env, projTransFromSRs) as Envelope;
        // Create inverse transformation, 3857 -> 4267
        ProjectionTransformation projTransFromSRsInverse =
            ArcGIS.Core.Geometry.ProjectionTransformation.Create(sr3857, sr4267);
        // Project the projected envelope back using the inverse transformation
        Envelope projectedEnvBack =
                 projectedEnvEx, projTransFromSRsInverse) as Envelope;
        bool isEqual = env.IsEqual(projectedEnvBack);
    Requirements
