ArcGIS.Core.Geometry Namespace / SpatialReferenceBuilder Class / SpatialReferenceBuilder Constructor / SpatialReferenceBuilder Constructor(Int32)
The well-known ID that represents the Spatial Reference.
Example
    Creates a new instance of the SpatialReferenceBuilder class. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function New( _
       ByVal wkid As Integer _
    public SpatialReferenceBuilder(
       int wkid
    Parameters
    wkid
    Exceptions
    ExceptionDescription
    Example
    Construct a SpatialReference - from a well-known ID
      // Use a builder convenience method or use a builder constructor.
      // SpatialReferenceBuilder convenience methods don't need to run on the MCT.
      SpatialReference sr3857 = SpatialReferenceBuilder.CreateSpatialReference(3857);
      // SpatialReferenceBuilder constructors need to run on the MCT.
      ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
        using (SpatialReferenceBuilder srBuilder = new SpatialReferenceBuilder(3857))
          // do something with the builder
          sr3857 = srBuilder.ToSpatialReference();
    Requirements
