ArcGIS.Core.Geometry Namespace / SpatialReferenceBuilder Class / SpatialReferenceBuilder Constructor / SpatialReferenceBuilder Constructor(Int32,String)
The well-known ID that represents the Spatial Reference.
The well-known text that represents the vertical coordinate system.
Example
    Creates a new instance of the SpatialReferenceBuilder class. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function New( _
       ByVal wkid As Integer, _
       ByVal vcsWkt As String _
    public SpatialReferenceBuilder(
       int wkid,
       string vcsWkt
    Parameters
    wkid
    vcsWkt
    Exceptions
    ExceptionDescription
    Example
    Construct a SpatialReference with a vertical coordinate system - from a string
      // Use a builder convenience method or use a builder constructor.
      // custom VCS - use vertical shift of -1.23 instead of 0
      string custom_vWkt = @"VERTCS[""SHD_height"",VDATUM[""Singapore_Height_Datum""],PARAMETER[""Vertical_Shift"",-1.23],PARAMETER[""Direction"",-1.0],UNIT[""Meter"",1.0]]";
      // Builder convenience methods don't need to run on the MCT.
      SpatialReference sr4326_customVertical = SpatialReferenceBuilder.CreateSpatialReference(4326, custom_vWkt);
      // SpatialReferenceBuilder properties
      //   sr4326_customVertical.wkid == 4326
      //   sr4326_customVertical.vert_wkid == 0
      //   sr4326_customVertical.vert_wkt == custom_vWkt
      //   sr4326_customVertical.hasVcs == true
      // SpatialReferenceBuilder constructors need to run on the MCT.
      ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
        using (SpatialReferenceBuilder sb = new SpatialReferenceBuilder(4326, custom_vWkt))
          // do something with the builder
          sr4326_customVertical = sb.ToSpatialReference();
    Requirements
