ArcGIS.Core.Geometry Namespace / SpatialReferenceBuilder Class / VcsWkt Property
    VcsWkt Property (SpatialReferenceBuilder)
    Gets or sets the vertical coordinate system well-known text. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public string VcsWkt {get; set;}
    Public Property VcsWkt As String
    Exceptions
    ExceptionDescription
    A spatial reference object cannot be altered once it has been initialized.
    Remarks
    The vertical coordinate system well-known text can be set at most once. If the vertical coordinate system well-known ID has already been set, then you can't set the well-known text.
    Requirements
