    ArcGIS.Desktop.Catalog Assembly
    This namespace contains types used by Graphic Tooltips Topology Rule.
    Namespaces
    NamespaceDescription
    This namespace contains classes that represent different types of project items such as folder connections, database connections, server connections, and so on. A class is also provided that lets you browse and select items using a dialog box.
    This namespace contains classes for working with BIM cloud items.
    This namespace contains classes and configuration types that are reserved for esri internal use only.
    This namespace contains classes for extending the portal API.
    This namespace contains classes for use with the portal API including portal items, portal queries, and portal query results.
