| Class | Description | |
![]() | BusinessAnalystProjectItem | Base class for file based business analyst project items. |
![]() | FolderConnectionProjectItem | Represents a folder connection project item. |
![]() | GDBProjectItem | Represents a database project item. |
![]() | HuffModelProjectItem | Represents a huff model project item. |
![]() | ItemCategoryDataSet | An item category for geodatabase datasets. |
![]() | ItemCategoryDataStore | An item category for geodatabase datastores. |
![]() | ItemDialog | Represents the Browse dialog box, which provides access to project items, portal items, and items available from a local or network disks. This is an abstract class. |
![]() | ItemFilters | Represents a filter that is used to narrow the list of items displayed in the Browse dialog box. |
![]() | LocatorsConnectionProjectItem | Represents a locator connection project item. |
![]() | OpenItemDialog | Opens the Browse dialog box and allows you to select one or more project items, portal items, or items available from a local or network disk. |
![]() | SaveItemDialog | Opens the Browse dialog box and allows you to save an item to the active portal or to a local or network disk. |
![]() | SegmentationProfileProjectItem | Represents a segmentation profile project item. |
![]() | SegmentationProjectItem | Represents a segmentation project item. |
![]() | SegmentationTargetGroupProjectItem | Represents a segmentation target group project item. |
![]() | ServerConnectionManager | This utility class is used to create or manage server connections. |
![]() | ServerConnectionProjectItem | Represents a server connection project item. |
![]() | StatisticalDataCollectionProjectItem | Represents a statistical data collection project item. |
![]() | VariableListProjectItem | Represents a variable list project item. |
