ArcGIS.Desktop.Catalog Namespace / OpenItemDialog Class / Items Property
Example
    Items Property (OpenItemDialog)
    Gets the items selected in the Browse dialog box.
    Syntax
    public IList<Item> Items {get;}
    Public ReadOnly Property Items As IList(Of Item)
    Example
    Show OpenItemDialog
      OpenItemDialog addToProjectDialog = new()
        Title = "Add To Project",
        InitialLocation = @"C:\Data\NewYork\Counties\Maps",
        MultiSelect = true,
        Filter = ItemFilters.Composite_Maps_Import
      bool? ok = addToProjectDialog.ShowDialog();
      if (ok == true)
        IEnumerable<Item> selectedItems = addToProjectDialog.Items;
        foreach (Item selectedItem in selectedItems)
          MapFactory.Instance.CreateMapFromItem(selectedItem);
    BrowseDialogItems
        MultiSelect = true,
      if (ok == true)
        IEnumerable<Item> selectedDialogItems = addToProjectDialog.Items;
        foreach (Item selectedDialogItem in selectedDialogItems)
          MapFactory.Instance.CreateMapFromItem(selectedDialogItem);
    Geodatabase Content from Browse Dialog
      var openDlg = new OpenItemDialog
        Title = "Select a Feature Class",
        InitialLocation = @"C:\Data",
        MultiSelect = false,
        BrowseFilter = BrowseProjectFilter.GetFilter(ItemFilters.GeodatabaseItems_All)
      //show the browse dialog
      bool? ok = openDlg.ShowDialog();
      if (!ok.HasValue || openDlg.Items.Count == 0)
        // nothing selected, leave
      var mapView = MapView.Active;
      await QueuedTask.Run(() =>
        // get the item
        var item = openDlg.Items.First();
        // see if the item has a dataset
        if (ItemFactory.Instance.CanGetDataset(item))
          // get it
          using var ds = ItemFactory.Instance.GetDataset(item);
          // access some properties
          var name = ds.GetName();
          var path = ds.GetPath();
          // if it's a featureclass
          if (ds is FeatureClass fc)
            // create a layer
            var featureLayerParams = new FeatureLayerCreationParams(fc)
              MapMemberIndex = 0
            var layer = LayerFactory.Instance.CreateLayer<FeatureLayer>(featureLayerParams, mapView.Map);
            // continue
    Workflow to open an ArcGIS Pro project using the OpenItemDialog
      BrowseProjectFilter portalAndLocalProjectsFilter = new();
      //A filter to pick projects from the portal
      //This filter will allow selection of ppkx and portal project items on the portal
      portalAndLocalProjectsFilter.AddFilter(BrowseProjectFilter.GetFilter("esri_browseDialogFilters_projects_online_proprojects"));
      //A filter to pick projects from the local machine
      portalAndLocalProjectsFilter.AddFilter(BrowseProjectFilter.GetFilter("esri_browseDialogFilters_projects"));
      //Create the OpenItemDialog and set the filter to the one we just created
      var openDlg = new OpenItemDialog()
        Title = "Select a Project",
        BrowseFilter = portalAndLocalProjectsFilter
      //Show the dialog
      var result = openDlg.ShowDialog();
      //Check if the user clicked OK and selected an item
        return; //nothing selected
      var selectedItem = openDlg.Items.FirstOrDefault();
      //Open the project use the OpenAsync method.
    Requirements
