ArcGIS.Desktop.Core Namespace / CreateProjectSettings Class / LocationPath Property
Example
    Gets and sets the location where the project will be stored
    Syntax
    Public Property LocationPath As String
    public string LocationPath {get; set;}
    Remarks
    If not set, projects are saved in the user's My Documents\ArcGIS\Projects folder; this folder is created if it doesn't already exist.
    If the LocationPath property is set, the new project will be created in the provided location; the specified folder must already exist on disk.
    LocationPath is ignored if the TemplateType is set to Untitled.
    Example
    Get the Default Project Folder
      //Get Pro's default project settings.
      var defaultSettings = Project.GetDefaultProjectSettings();
      var defaultProjectPath = defaultSettings.LocationPath;
      // If not set, projects are saved in the user's My Documents\ArcGIS\Projects folder;
      // this folder is created if it doesn't already exist.
      defaultProjectPath ??= Path.Combine(
                  Environment.GetFolderPath(
                       Environment.SpecialFolder.MyDocuments),
                  @"ArcGIS\Projects");
      // Use defaultProjectPath;
    Requirements
