The default project name is "MyProject". If not set, a name is generated appropriately for the LocationPath. For example, if the LocationPath already contains projects named MyProject, MyProject1 and MyProject2, the name MyProject3 will be used for the new project.
If the Name property is set, the provided name will be used when the project is created. If another project with the same name already exists at LocationPath, the name will be incremented; for example, if the name "TestProject" is provided, the new project will be named TestProject1.
