ArcGIS.Desktop.Core Namespace / EsriHttpClient Class / Upload Method
The upload definition
Example
    Upload Method
    Uploads an item to the specified Uri identifying a portal/server as a synchronous operation.
    Syntax
    Parameters
    uploadDefinition
    Return Value
    System.Tuple A binary tuple consisting of a bool and an ItemID. The bool indicates whether the method succeeded or failed.
    Remarks
    The following items are currently supported:
    ArcGIS Geoprocessing package (gpk)
    ArcGIS Locator package (gcpk)
    ArcGIS Map package (mpk)
    ArcGIS Mobile Basemap package (bpk)
    ArcGIS Mobile Map package (mmpk)
    ArcGIS Server Globe service
    ArcGIS Server Geometry service
    ArcGIS Server Geoprocessing service
    ArcGIS Server Geodata service
    ArcGIS Server Network analysis service
    ArcGIS Task file (esriTasks)
    Arcmap document (mxd)
    CSV: A text file of data values separated by commas or other delimiters (csv)
    Feature service
    Geocoding service
    Image service
    KML file
    Layer file (lyr) or (lyrx)
    Layer package (lpk)
    Map service
    Microsoft Excel Document (.xls, .xlsx)
    Tile package (tpk)
    Compact Tile package (tpkx)
    Vector Tile package (vtpk)
    Example
    EsriHttpClient: Upload CSV file to ArcGIS Online
      // Create the item to be uploaded, based on a local file
      var itemToUpload = ItemFactory.Instance.Create(@"C:\Data\AddToMapCustomItem\AlaskaCitiesXY.csv");
      // Define the tags for the item
      string[] tags = new string[] { "ArcGIS Pro", "SDK", "Internal Demo" };
      // Create the upload definition for the above item
      UploadDefinition uploadDefinition = new UploadDefinition(
        ArcGISPortalManager.Current.GetActivePortal().PortalUri.ToString(),
        itemToUpload,
        tags
      // Upload the item to the Portal
      EsriHttpClient httpClient = new EsriHttpClient();
      var result = httpClient.Upload(uploadDefinition);
      // Manage the result of the operation appropriately
      if (result.Item1 == false)
        return;
    Requirements
