Public Class ItemFactory Implements IItemFactory
public class ItemFactory : IItemFactory
// Import a mxd
Item mxdToImport = ItemFactory.Instance.Create(@"C:\Projects\RegionalSurvey\LatestResults.mxd");
// Note: Needs QueuedTask to run
var addedMxd = Project.Current.AddItem(mxdToImport as IProjectItem);
// Add map package
Item mapPackageToAdd = ItemFactory.Instance.Create(@"c:\Data\Map.mpkx");
var addedMapPackage = Project.Current.AddItem(mapPackageToAdd as IProjectItem);
// Add an exported Pro map
Item proMapToAdd = ItemFactory.Instance.Create(@"C:\ExportedMaps\Election\Districts.mapx");
var addedMapProjectItem = Project.Current.AddItem(proMapToAdd as IProjectItem);
//Adding a folder connection
//Create the folder connection project item
var item = ItemFactory.Instance.Create(folderPath) as IProjectItem;
var folder = Project.Current.AddItem(item) ? item as FolderConnectionProjectItem : null;
//Adding a Geodatabase:
//Create the File GDB project item
var item = ItemFactory.Instance.Create(gdbPath) as IProjectItem;
var newlyAddedGDB = Project.Current.AddItem(item) ? item as GDBProjectItem : null;
var templateFileName = "Layout.pagx";
// Get layout Template Path from the project's home folder and combine it with a file name
var projectPath = CoreModule.CurrentProject.HomeFolderPath;
var layoutTemplateFilePath = System.IO.Path.Combine(projectPath, templateFileName);
// Create a new layout project item with the layout file path
// Create an IProjectItem using a layout template pagx file
IProjectItem pagx = ItemFactory.Instance.Create(layoutTemplateFilePath) as IProjectItem;
// Add the IProjectItem to the current project
//Note: Needs QueuedTask to run
Project.Current.AddItem(pagx);
//Create a layout project item from importing a pagx file
@"C:\Temp\Layout.pagx") as IProjectItem;
// Create the item to be uploaded, based on a local file
var itemToUpload = ItemFactory.Instance.Create(@"C:\Data\AddToMapCustomItem\AlaskaCitiesXY.csv");
// Define the tags for the item
string[] tags = new string[] { "ArcGIS Pro", "SDK", "Internal Demo" };
// Create the upload definition for the above item
UploadDefinition uploadDefinition = new UploadDefinition(
ArcGISPortalManager.Current.GetActivePortal().PortalUri.ToString(),
itemToUpload,
tags
// Upload the item to the Portal
EsriHttpClient httpClient = new EsriHttpClient();
var result = httpClient.Upload(uploadDefinition);
// Manage the result of the operation appropriately
if (result.Item1 == false)
return;
var reportFilePath = @"c:\temp\Report.rptx";
//Note: Call within QueuedTask.Run()
Item reportToImport = ItemFactory.Instance.Create(reportFilePath);
Project.Current.AddItem(reportToImport as IProjectItem);
System.Object
ArcGIS.Desktop.Core.ItemFactory
