ArcGIS.Desktop.Core Namespace / ItemFactory Class
Properties Methods
    ItemFactory Class Members
    The following tables list the members exposed by ItemFactory.
    Public Properties
     NameDescription
    Public Propertystatic (Shared in Visual Basic) Gets the IItemFactory instance
    Top
    Public Methods
     NameDescription
    Public Method Gets if the dataset for the item can be retrieved.
    Public Method Gets if the definition for the item can be retrieved.
    Public Method Gets if the Knowledge Graph named object type for the item can be retrieved.
    Public MethodCreates a Item representing the resource identified by the Uri
    Public MethodGets the ArcGIS.Core.Data.Dataset associated with the item corresponding to Item.Path. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets the ArcGIS.Core.Data.DatasetType for the item. If the dataset type cannot be determined, then ArcGIS.Core.Data.DatasetType.Unknown is returned.
    Public MethodGets the ArcGIS.Core.Data.Definition associated with the item corresponding to Item.Path. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets the ArcGIS.Core.Data.Knowledge.KnowledgeGraphNamedObjectType associated with the item corresponding to Item.Path. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverloaded.
    Top
