ReadOnly Property ErrorMessages As IEnumerable(Of IGPMessage)
IEnumerable<IGPMessage> ErrorMessages {get;}
var warnings = result.Messages.Where(it => it.Type == GPMessageType.Error);
//The data referenced in this snippet can be downloaded from the arcgis-pro-sdk-community-samples repo
//https://github.com/Esri/arcgis-pro-sdk-community-samples
var paramsArray = Geoprocessing.MakeValueArray(currentTemplate.MapMember.Name,
@"C:\Data\FeatureTest\FeatureTest.gdb\Points_MultipleRingBuffer",
new List<string> { "1000", "2000" }, "Meters", "Distance",
"ALL", "FULL");
IGPResult gpResult = Geoprocessing.ExecuteToolAsync("Analysis.MultipleRingBuffer", paramsArray).Result;
var messages = string.IsNullOrEmpty(gpResult.ReturnValue)
? $@"Error in Geoprocessing tool: {gpResult.ErrorMessages}"
: $@"Ok: {gpResult.ReturnValue}";
// use the messages and the result as needed
string in_data = @"C:\tools\data.gdb\cities";
string cities_buff = @"E:\data\data.gdb\cities_2km";
var valueArray = Geoprocessing.MakeValueArray(in_data, cities_buff, "2000 Meters");
// to let the GP tool run asynchronously without blocking the main thread
// use the GPThread option of GPExecuteToolFlags
GPExecuteToolFlags flags = GPExecuteToolFlags.GPThread; // instruct the tool run non-blocking GPThread
IGPResult bufferResult = Geoprocessing.ExecuteToolAsync("Analysis.Buffer", valueArray, null, null, null, flags).Result;
