ArcGIS.Desktop.Editing Namespace / EditOperation Class / Modify Method / Modify(Row,Dictionary<String,Object>) Method
The row to update.
The attribute values to update (by field name).
Example
    Modify a row, updating the attribute values. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub Modify( _
       ByVal row As Row, _
       ByVal attributes As Dictionary(Of String,Object) _
    public void Modify(
       Row row,
       Dictionary<string,object> attributes
    Parameters
    row
    The row to update.
    attributes
    Exceptions
    ExceptionDescription
    Example
    Edit Operation Modify single feature
    // Modifies a single feature in the specified feature layer.
    await QueuedTask.Run(() =>
        var modifyFeature = new EditOperation() { Name = "Modify a feature" };
        //use an inspector
        var modifyInspector = new Inspector();
        modifyInspector.Load(featureLayer, objectId);//base attributes on an existing feature
        //change attributes for the new feature
        modifyInspector["SHAPE"] = polygon;//Update the geometry
        modifyInspector["NAME"] = "Updated name";//Update attribute(s)
        modifyFeature.Modify(modifyInspector);
        //update geometry and attributes using overload
        var featureAttributes = new Dictionary<string, object>
          ["NAME"] = "Updated name"//Update attribute(s)
        modifyFeature.Modify(featureLayer, objectId, polygon, featureAttributes);
        //Execute to execute the operation
        //Must be called within QueuedTask.Run
        if (!modifyFeature.IsEmpty)
          //Execute and ExecuteAsync will return true if the operation was successful and false if not
          var result = modifyFeature.Execute();
          //or use async flavor
          //await modifyFeatures.ExecuteAsync();
    Move feature to a specific coordinate
    // Moves the first selected feature in the specified feature layer to the given coordinates.
    await QueuedTask.Run<bool>(() =>
       //Get all of the selected ObjectIDs from the layer.
       var mySelection = featureLayer.GetSelection();
       var selOid = mySelection.GetObjectIDs()?[0];
       var xCoordinate = 0.0;
       var yCoordinate = 0.0; // specify the target coordinates to move the geometry
       var moveToPoint = new MapPointBuilderEx(xCoordinate, yCoordinate, 0.0, 0.0, featureLayer.GetSpatialReference());
       var moveEditOperation = new EditOperation() { Name = "Move features" };
       moveEditOperation.Modify(featureLayer, selOid ?? -1, moveToPoint.ToGeometry());  //Modify the feature to the new geometry
       if (!moveEditOperation.IsEmpty)
         var result = moveEditOperation.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
         return result; // return the operation result: true if successful, false if not
       return false; // return false to indicate that the operation was not empty
    Order edits sequentially
    // Modifies the "NAME" attribute of a specified feature and then splits the feature using the provided polyline, all within a single sequential edit operation.
    // perform an edit and then a split as one operation.
       var newName = "Modified then Split";
       var queryFilter = new QueryFilter() { WhereClause = "OBJECTID = " + objectId.ToString() };
       // create an edit operation and name.
       var op = new EditOperation
         Name = "modify followed by split",         // set the ExecuteMode
         ExecuteMode = ExecuteModeType.Sequential
       using (var rowCursor = layer.Search(queryFilter))
         while (rowCursor.MoveNext())
           using var feature = rowCursor.Current as ArcGIS.Core.Data.Feature;
           op.Modify(feature, "NAME", newName);
       op.Split(layer, objectId, splitLine);
       if (!op.IsEmpty)
         bool result = op.Execute();
       // else
       //  The operation doesn't make any changes to the database so if executed it will fail
    Read and Write blob fields with the attribute inspector
      // get selected feature into inspector
      var selectedFeatures = activeMap.GetSelection();
      var insp = new Inspector();
      insp.Load(selectedFeatures.ToDictionary().Keys.First(), selectedFeatures.ToDictionary().Values.First());
      // read a blob field and save to a file
      var msw = new MemoryStream();
      msw = insp["BlobField"] as MemoryStream;
      using (FileStream file = new(@"d:\temp\blob.jpg", FileMode.Create, FileAccess.Write))
        msw.WriteTo(file);
      // read file into memory stream
      var msr = new MemoryStream();
      using (FileStream file = new(@"d:\images\Hydrant.jpg", FileMode.Open, FileAccess.Read))
        file.CopyTo(msr);
      //put the memory stream in the blob field and save to feature
      var op = new EditOperation() { Name = "Blob Inspector" };
      insp["Blobfield"] = msr;
      op.Modify(insp);
      if (!op.IsEmpty)
        var result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
    Write a compressed image to a raster field
      //Open the raster dataset on disk and create a compressed raster value dataset object
      var dataStore = new ArcGIS.Core.Data.FileSystemDatastore(new ArcGIS.Core.Data.FileSystemConnectionPath(new Uri(@"e:\temp"), ArcGIS.Core.Data.FileSystemDatastoreType.Raster));
      using (var fileRasterDataset = dataStore.OpenDataset<ArcGIS.Core.Data.Raster.RasterDataset>("Hydrant.jpg"))
        var storageDef = new ArcGIS.Core.Data.Raster.RasterStorageDef();
        storageDef.SetCompressionType(ArcGIS.Core.Data.Raster.RasterCompressionType.JPEG);
        storageDef.SetCompressionQuality(90);
        var rv = new ArcGIS.Core.Data.Raster.RasterValue();
        rv.SetRasterDataset(fileRasterDataset);
        rv.SetRasterStorageDef(storageDef);
        var sel = MapView.Active.Map.GetSelection();
        //insert a raster value object into the raster field
        var insp = new ArcGIS.Desktop.Editing.Attributes.Inspector();
        insp.Load(sel.ToDictionary().Keys.First(), sel.ToDictionary().Values.First());
        insp["Photo"] = rv;
        var op = new EditOperation() { Name = "Raster Inspector" };
        op.Modify(insp);
        if (!op.IsEmpty)
    Update Annotation Text via attribute.
      var oid = 1;
      // See "Change Annotation Text Graphic" for an alternative if TEXTSTRING is missing from the schema
      // Note: QueuedTask is required to access the Inspector
        // use the inspector methodology
        insp.Load(annotationLayer, oid);
        // make sure TextString attribute exists.
        //It is not guaranteed to be in the schema
        ArcGIS.Desktop.Editing.Attributes.Attribute att = insp.FirstOrDefault(a => a.FieldName == "TEXTSTRING");
        if (att != null)
          insp["TEXTSTRING"] = "Hello World";
          //create and execute the edit operation
          EditOperation op = new EditOperation();
          op.Name = "Update annotation";
          op.Modify(insp);
          //OR using a Dictionary - again TEXTSTRING has to exist in the schema
          //Dictionary<string, object> newAtts = new Dictionary<string, object>();
          //newAtts.Add("TEXTSTRING", "hello world");
          //op.Modify(annotationLayer, oid, newAtts);
          op.Execute();
    Edit the attributes of a FeatureSceneLayer
      //must support editing!
      if (!featSceneLayer.HasAssociatedFeatureService ||
          !featSceneLayer.IsEditable)
        return;
      // Note: call within QueuedTask.Run()
        var editOp = new EditOperation()
          Name = "Edit FeatureSceneLayer Attributes",
          SelectModifiedFeatures = true
        //make an inspector
        var inspector = new Inspector();
        //get the attributes for the specified oid
        inspector.Load(featSceneLayer, oid);
        inspector["PermitNotes"] = "test";//modify
        editOp.Modify(inspector);
        editOp.Execute();//synchronous flavor
    Requirements
