ArcGIS.Desktop.Editing.Events Namespace / RowCreatedEvent Class / Subscribe Method
The delegate that gets executed when the event is published.
The table to listen to.
(optional) The type of reference used to maintain the delegate. false is a weak reference, true is a strong reference. (default value = false)
Example
    Subscribe Method (RowCreatedEvent)
    Subscribes to RowCreatedEvents that are published when a row is created. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    action
    table
    keepSubscriberAlive
    Return Value
    A token that uniquely identifies the subscription.
    Exceptions
    ExceptionDescription
    Example
    Subscribe to Row Events
    // Subscribes to row events for the currently selected feature layer in the active map view.
    await QueuedTask.Run(() =>
      //Listen for row events on a layer
      var featLayer = MapView.Active.GetSelectedLayers()[0] as FeatureLayer;
      var layerTable = featLayer.GetTable();
      //subscribe to row events
      // row created event
      var rowCreateToken = RowCreatedEvent.Subscribe(rowChangedEventArgs => { }, layerTable);
      // row changed event
      var rowChangeToken = RowChangedEvent.Subscribe(rowChangedEventArgs => { }, layerTable);
      // row deleted event
      var rowDeleteToken = RowDeletedEvent.Subscribe(rowChangedEventArgs => { }, layerTable);
    Requirements
