ArcGIS.Desktop.Editing.Templates Namespace / EditingTemplate Class / GetDefinition Method
Example
    GetDefinition Method (EditingTemplate)
    Gets the CIM definition of this EditingTemplate. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetDefinition() As CIMEditingTemplate
    public CIMEditingTemplate GetDefinition()
    Exceptions
    ExceptionDescription
    Example
    Change Default Edit tool for a template
    await QueuedTask.Run(() =>
            var templateName = "Distribution"; // name of the template to update
            var toolDamlPlugInID = "esri_editing_SketchTwoPointLineTool"; // DAML ID of the tool to set as default
            var toolContentGUID = "e2096d13-b437-4bc1-94ea-4494c3260f72"; // Example GUID, replace with actual GUID from DAML
        // retrieve the edit template form the layer by name
            var template = featureLayer?.GetTemplate(templateName) as EditingTemplate;
            // get the definition of the layer
            var layerDef = featureLayer?.GetDefinition() as CIMFeatureLayer;
            if (template == null || layerDef == null)
              return;
            if (template.DefaultToolID != toolDamlPlugInID)
              bool updateLayerDef = false;
              if (layerDef.AutoGenerateFeatureTemplates)
                layerDef.AutoGenerateFeatureTemplates = false;
                updateLayerDef = true;
              // retrieve the CIM edit template definition
              var templateDef = template.GetDefinition();
              // assign the GUID from the tool DAML definition, for example
              // <tool id="TestConstructionTool_SampleSDKTool" categoryRefID="esri_editing_construction_polyline" ….>
              //   <tooltip heading="">Tooltip text<disabledText /></tooltip>
              //   <content guid="e58239b3-9c69-49e5-ad4d-bb2ba29ff3ea" />
              // </tool>
              // then the toolContentGUID would be "e58239b3-9c69-49e5-ad4d-bb2ba29ff3ea"
              //templateDef.ToolProgID = toolContentGUID;
              templateDef.DefaultToolGUID = toolContentGUID;
              // set the definition back to
              template.SetDefinition(templateDef);
              // update the layer definition too
              if (updateLayerDef)
                featureLayer.SetDefinition(layerDef);
    Hide or show editing tools on templates
         //hide all tools except line tool on a given feature layer
         var editTemplates = featureLayer.GetTemplates();
         var newCIMEditingTemplates = new List<CIMEditingTemplate>();
         foreach (var et in editTemplates)
           //initialize template by activating default tool
           et.ActivateDefaultToolAsync();
           var cimEditTemplate = et.GetDefinition();
           //get the visible tools on this template
           var allTools = et.ToolIDs.ToList();
           //add the hidden tools on this template
           allTools.AddRange(cimEditTemplate.GetExcludedToolIDs().ToList());
           //hide all the tools then allow the line tool
           cimEditTemplate.SetExcludedToolIDs(allTools.ToArray());
           cimEditTemplate.AllowToolID("esri_editing_SketchLineTool");
           newCIMEditingTemplates.Add(cimEditTemplate);
         //update the layer templates
         var layerDef = featureLayer.GetDefinition() as CIMFeatureLayer;
         // Set AutoGenerateFeatureTemplates to false for template changes to stick
         layerDef.FeatureTemplates = newCIMEditingTemplates.ToArray();
    Create New Table Template using table.CreateTemplate
    // Creates new table templates for the specified standalone table.
      var table = activeMap.GetStandaloneTablesAsFlattenedList().FirstOrDefault();
      var tableTemplate = table.GetTemplate("Template1");
      var definition = tableTemplate.GetDefinition();
      definition.Description = "New definition";
      definition.Name = "New name";
      //Create new table template using this definition
      table.CreateTemplate(definition);
      //You can also create a new table template using this extension method. You can use this method the same way you use the layer.CreateTemplate method.
      table.CreateTemplate("New template name", "Template description", tags: ["tag 1", "tag 2"]);
    Update a Table Template
    // Updates the definition of a specified table template by modifying its name and description.
        // get a table template
        var tableTemplate = table.GetTemplate("Template1") ?? throw new Exception("No table template named 'Template1' found");
        // update the definition
        tableTemplate.SetDefinition(definition);
    Requirements
