ArcGIS.Desktop.Editing.Templates Namespace / EditingTemplate Class / SetDefinition Method
the new CIM definition for this template.
Example
    SetDefinition Method (EditingTemplate)
    Sets the CIM definition of this EditingTemplate. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetDefinition( _
       ByVal definition As CIMEditingTemplate _
    public void SetDefinition(
       CIMEditingTemplate definition
    Parameters
    definition
    Exceptions
    ExceptionDescription
    Example
    Change Default Edit tool for a template
    await QueuedTask.Run(() =>
            var templateName = "Distribution"; // name of the template to update
            var toolDamlPlugInID = "esri_editing_SketchTwoPointLineTool"; // DAML ID of the tool to set as default
            var toolContentGUID = "e2096d13-b437-4bc1-94ea-4494c3260f72"; // Example GUID, replace with actual GUID from DAML
        // retrieve the edit template form the layer by name
            var template = featureLayer?.GetTemplate(templateName) as EditingTemplate;
            // get the definition of the layer
            var layerDef = featureLayer?.GetDefinition() as CIMFeatureLayer;
            if (template == null || layerDef == null)
              return;
            if (template.DefaultToolID != toolDamlPlugInID)
              bool updateLayerDef = false;
              if (layerDef.AutoGenerateFeatureTemplates)
                layerDef.AutoGenerateFeatureTemplates = false;
                updateLayerDef = true;
              // retrieve the CIM edit template definition
              var templateDef = template.GetDefinition();
              // assign the GUID from the tool DAML definition, for example
              // <tool id="TestConstructionTool_SampleSDKTool" categoryRefID="esri_editing_construction_polyline" ….>
              //   <tooltip heading="">Tooltip text<disabledText /></tooltip>
              //   <content guid="e58239b3-9c69-49e5-ad4d-bb2ba29ff3ea" />
              // </tool>
              // then the toolContentGUID would be "e58239b3-9c69-49e5-ad4d-bb2ba29ff3ea"
              //templateDef.ToolProgID = toolContentGUID;
              templateDef.DefaultToolGUID = toolContentGUID;
              // set the definition back to
              template.SetDefinition(templateDef);
              // update the layer definition too
              if (updateLayerDef)
                featureLayer.SetDefinition(layerDef);
    Update a Table Template
    // Updates the definition of a specified table template by modifying its name and description.
    var table = activeMap.GetStandaloneTablesAsFlattenedList().FirstOrDefault();
        // get a table template
        var tableTemplate = table.GetTemplate("Template1") ?? throw new Exception("No table template named 'Template1' found");
        var definition = tableTemplate.GetDefinition();
        definition.Description = "New definition";
        definition.Name = "New name";
        // update the definition
        tableTemplate.SetDefinition(definition);
    Requirements
