An overview of the Raster Surface toolset
Available with 3D Analyst license.
Available with Spatial Analyst license.
With the Raster Surface tools, you can quantify and visualize a terrain landform represented by a digital elevation model.
Starting with a raster elevation surface as input, with these tools, you can gain information by producing a new dataset that identifies a specific pattern within an original dataset. You can derive patterns that were not readily apparent in the original surface, such as contours, angle of slope, steepest downslope direction, and shaded relief.
Each surface tool provides insight into a surface that can be used as an end in itself or as input to additional analysis.
Tool
Aspect
Derives the aspect from each cell of a raster surface.
Contour
Creates a feature class of contours from a raster surface.
Contour List
Creates a feature class of selected contour values from a raster surface.
Contour with Barriers
Creates contours from a raster surface. The inclusion of barrier features allows you to independently generate contours on either side of a barrier.
Curvature
Calculates the curvature of a raster surface and, optionally, includes profile and plan curvature.
Cut Fill
Calculates the volume change between two surfaces. This is typically used for cut and fill operations.
Hillshade
Creates a shaded relief from a surface raster by considering the illumination source angle and shadows.
Slope
Identifies the slope (gradient or steepness) from each cell of a raster.
Surface Parameters
Determines parameters of a raster surface such as aspect, slope, and curvatures.
Tools of the Raster Surface toolset
