Generate Near Table 3D (3D Analyst Tools)
Summary
Calculates distances and other proximity information between features in one or more feature classes or layers.
Unlike the Near 3D tool, which modifies the input, this tool writes results to a new table and supports finding more than one near feature. It also gives the option of outputting points or lines to represent the nearest from and to locations and the lines connecting them.
Usage
  • The output table will contain the following fields:
    • IN_FID—The Object ID of the input feature.
    • NEAR_FID—The Object ID of the nearest feature.
    • NEAR_DIST—The horizontal distance from the input feature to the near feature. The value is in the linear unit of the input feature's coordinate system.
    • NEAR_DIST3—The 3D distance from the input feature to the near feature. The value is in the linear unit of the input feature's coordinate system.
    • NEAR_FC—The catalog path to the feature class that contains the near feature. This field is only added to the output table if multiple Near Features parameter values are specified.
    • NEAR_RANK—An integer value ranking all near features based on their proximity to an individual input feature. The closest feature will have a value of 1, the second closest will have a value of 2, and so on. This field is only added to the output table when the Find only closest feature parameter is unchecked and the Maximum number of closest matches parameter value is greater than 1.
  • The following fields will be added to the output table if the Location parameter is checked. The field value will be in the linear unit of the input feature's coordinate system.
    • FROM_X—The x-coordinate of the location on the input feature that is closest to the near feature.
    • FROM_Y—The y-coordinate of the location on the input feature that is closest to the near feature.
    • FROM_Z—The z-coordinate of the location on the input feature that is closest to the near feature.
    • NEAR_X—The x-coordinate of the location on the near feature that is closest to the input feature.
    • NEAR_Y—The y-coordinate of the location on the near feature that is closest to the input feature.
    • NEAR_Z —The z-coordinate of the location on the near feature that is closest to the input feature.
  • The following fields will be added to the output table if the Angle parameter is checked:
    • NEAR_ANG_H—The horizontal angle of the line at the FROM_X, FROM_Y, FROM_Z location that connects the input feature to the near feature.
    • NEAR_ANG_V—The vertical angle of the line at the FROM_X, FROM_Y, FROM_Z location that connects the input feature to the near feature.
  • The following fields will be added to the output table if the Delta parameter is checked:
    • NEAR_DELTX—The distance along the X axis from the nearest location on the input feature to the nearest location on the nearest feature.
    • NEAR_DELTY—The distance along the Y axis from the nearest location on the input feature to the nearest location on the nearest feature.
    • NEAR_DELTZ—The distance along the Z axis from the nearest location on the input feature to the nearest location on the nearest feature.
  • The following field will be added to the output table if an Output Lines parameter value is specified:
    • LINE_ID—The OBJECTID of the polyline feature created to represent the shortest path from the input feature to the near feature.
  • The following fields will be added to the output table if the Output Points parameter value is specified:
    • FROM_PT_ID—The OBJECTID of the point feature created to represent the location on the input feature that is closest to the near feature.
    • TO_PT_ID—The OBJECTID of the point feature created to represent the location on the near feature that is closest to the input feature.
  • When the input feature and near feature intersect, the following values will be written to the output table:
    • NEAR_DIST, NEAR_DIST3, NEAR_ANG_H, and NEAR_ANG_V will be set to 0.0.
    • FROM_X, FROM_Y and FROM_Z will be identical to NEAR_X, NEAR_Y and NEAR_Z and will be a location within the intersection of the two features.
  • The values for the NEAR_DIST and NEAR_DIST3 fields will be in the linear unit of the input feature's coordinate system.
  • The output table can be joined back to the input features using the IN_FID field or to the near features using the NEAR_FID field.
  • You can enter values for any combination of the Search Radius 2D, Search Radius 3D, Search Above Max, and Search Below Max parameters, or for none of them.
  • If a value is specified for at least one of the Search Radius 2D, Search Radius 3D, Search Above Max, and Search Below Max parameters, and no near feature is found, no record will be output.
  • If no values are specified for any of the Search Radius 2D, Search Radius 3D, Search Above Max, and Search Below Max parameters, all near features will be considered candidates.
  • If no values are specified for any of the Search Radius 2D, Search Radius 3D, Search Above Max, and Search Below Max parameters, the Find only closest feature parameter is unchecked, and the Maximum number of closest matches parameter is set to the default (0 or empty), the output table will contain distance calculations between all input features and all near features. This process may take a long time and create a large output table. For example, if you have 1,000 input features and 1,000 near features, the output table will contain 1 million records.
  • To calculate distance and additional proximity information within a single feature class or layer, the same feature class or layer can be specified in both the Input Features parameter and the Near Features parameter. In this situation, the input feature being evaluated will be excluded from the near features candidates to avoid all features being closest to themselves.
  • Use a projection for the input features that is appropriate for distance measurement, such as an equidistant projection.
  • To visualize the FROM_X, FROM_Y, FROM_Z, NEAR_X, NEAR_Yand NEAR_Z field values, use the output table as input to the Make XY Event Layer tool.
  • If you specify an output line feature class, it will contain the following attributes so that you can determine what each line feature represents and its 3D length: OUTTBL_OID (the OBJECTID of the row in the output table) and LENGTH_3D. The line will consist of two vertices; the first one will be on the input feature, and the second one will be on the near feature.
  • If you specify an output point feature class, it will contain the following attributes so that you can determine what each point feature represents: OUTTBL_OID and ON_NEARFTR. ON_NEARFTR will contain 0 if the point is at the location of the nearest location on the input feature, or 1 if the point is at the location of the nearest location on the near feature.
  • You can set a unit of measurement for the NEAR_DIST and NEAR_DIST3 fields—such as meters, kilometers, or miles—using the Distance Unit parameter. Use the Vertical Unit parameter to specify the unit of measurement for the DELTA_Z field.
Learn more about coordinate systems and projections
Parameters
Label Explanation Data type
Input Features
The input features, which can be 3D point, 3D polyline, 3D polygon, 3D multipoint, or multipatch type.
Feature Layer
Near Features
One or more feature layers or feature classes containing near feature candidates. The near features can be 3D point, 3D polyline, 3D polygon, 3D multipoint, or multipatch. If multiple layers or feature classes are specified, the NEAR_FC field will be added to the output table and will store the paths of the source feature class containing the nearest feature found. The same feature class or layer can be used as both input features and near features.
Feature Layer
Output Table
The output table containing the result of the analysis.
Table
Output Lines
(Optional)
An optional line feature class. Each line feature represents the path from the location on the closest part of the input feature to the location on the closest part of the near feature. Each line feature in this output represents one row in the output table and consists of just two vertices. These two vertices match the locations of the optional output points (two points for each line). The direction of the line is from the input feature to the near feature. Lines can be output even if points are not output.
Feature Class
Output Points
(Optional)
An optional point feature class. For each row in the output table, two point features will be output, one representing the location on the closest part of the input feature and one representing the location on the closest part of the near feature. Each such pair of points matches the two vertices of the output line feature representing the same row in the output table. Points can be output even if lines are not output.
Feature Class
Search Radius 2D
(Optional)
The horizontal radius that will be used to search for near features. If no value is specified, all near features will be considered. If a distance but no unit or unknown is specified, the units of the coordinate system of the input features will be used.
Linear Unit
Search Radius 3D
(Optional)
This is the same as Search Radius 2D, but in 3D, forming an imaginary sphere.
Linear Unit
Search Above Max
(Optional)
The maximum vertical distance above the input feature to look for near features.
Linear Unit
Search Below Max
(Optional)
The maximum vertical distance below the input feature to look for near features.
Linear Unit
Location
(Optional)
Specifies whether x-, y-, and z-coordinates of the input feature's location and closest location of the near feature will be written to the FROM_X, FROM_Y, FROM_Z, NEAR_X, NEAR_Y, and NEAR_Z fields.
  • Checked—Locations will be written to the output table.
  • Unchecked—Locations will not be written to the output table. This is the default.
Boolean
Angle
(Optional)
Specifies whether the near angles will be calculated and written to the NEAR_ANG_H and NEAR_ANG_V fields in the output table. A near angle measures direction of the line connecting an input feature to its nearest feature at their closest location. The angle will be within the range of -180° to 180°, with 0° being to the east, 90° to the north, 180° (or -180°) to the west, and -90° to the south.
  • Checked—The near angles will be calculated, and the NEAR_ANG_H and NEAR_ANG_V fields will be added to the output table
  • Unchecked—The near angles will not be calculated, and the NEAR_ANG_H and NEAR_ANG_V fields will not be added to the output table. This is the default.
Boolean
Delta
(Optional)
Specifies whether the delta values will be calculated and written to the NEAR_DELTX, NEAR_DELTY, and NEAR_DELTZ fields in the output table. The delta value for each axis is the distance along that axis from the nearest point on the input feature to the nearest point on the nearest feature. The value can be positive, zero, or negative, depending upon the direction.
  • Checked—The deltas will be calculated, and the NEAR_DELTX, NEAR_DELTY, and NEAR_DELTZ fields will be added to the output table.
  • Unchecked—The deltas will not be calculated, and the NEAR_DELTX, NEAR_DELTY, and NEAR_DELTZ fields will not be added to the output table. This is the default.
Boolean
(Optional)
Specifies whether only the closest near feature will be written to the output table. When unchecked, the Maximum number of closest matches parameter will appear.
  • Checked—Only the closest near feature will be written to the output table. This is the default.
  • Unchecked—Multiple near features will be written to the output table. A limit can be specified in the Maximum number of closest matches parameter.
Boolean
(Optional)
The number of near features that will be reported for each input feature. This parameter is ignored if the Find only closest feature parameter is checked.
Long
Distance Unit
(Optional)
Specifies the unit of measurement for the NEAR_DIST, NEAR_DIST3, NEAR_DELTX, NEAR_DELTY, and NEAR_DELTZ fields. When no unit of measurement is specified, the values in these fields will be in the linear unit of the input feature's coordinate system.
  • Kilometers—The unit will be kilometers.
  • Meters—The unit will be meters.
  • International Nautical Miles—The unit will be international nautical miles.
  • Statute Miles—The unit will be statute miles.
  • International Yards—The unit will be international yards.
  • International Feet—The unit will be international feet.
  • US Survey Nautical Miles—The unit will be U.S. survey nautical miles.
  • Miles—The unit will be U.S. survey miles.
  • Yards—The unit will be U.S. survey yards.
  • Feet—The unit will be U.S. survey feet.
String
Vertical Unit
(Optional)
Specifies the unit of measurement for the DELTA_Z field.
String
Match Fields
(Optional)
The pairs of fields from the input features and near features that will be used for attribute matching. Only the near features that share match field values with the input features will be used in the near calculation.
Value table columns:
  • Input Features—Fields from the input features that will be used for attribute matching.
  • Near Features—Fields from the near features that will be used for attribute matching.
Value Table
Environments
Current Workspace
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
