Surface analysis sample applications
Available with 3D Analyst license.
Available with Spatial Analyst license.
The following are a selection of the many applications for raster surface analysis tools.
Type of analysis
Surface tool(s)
Application
Characteristics of surfaces
Surface Parameters
Compute multiple analytic descriptors of a surface, typically elevation data. Use this tool to identify areas too steep for development or prone to landslide. Create inputs for plant growth models and phenomena that are effected by their aspect relative to the sun. Classify landforms and inform understanding of geomorphologic processes.
Slope
You might want to know the variations in the slope of the landscape because you want to find the areas most at risk of landslide based on the angle of steepness in an area (steeper slopes being those most at risk).
Aspect
You might be a farmer who is interested in locating a field in an area with a southerly aspect.
Curvature
Determine the acceleration and convergence of flow in a drainage basin to better understand erosion.
Creating contours
Contour
Contour List
Contour with Barriers
Contours can be useful for finding areas of the same value. You could be interested in obtaining elevation values for specific locations and examining the overall gradation of the land.
Terrain relief and visualization
Hillshade
You can create hillshade for both graphic and analytic purposes. Graphically, a hillshade can provide an attractive and realistic backdrop, showing how other layers are distributed in relation to the terrain relief. From an analytic point of view, you can analyze how the landscape is illuminated at various times of the day by lowering and raising the sun angle.
Volumetric analysis
Cut Fill
You may be leveling a site for building construction and want to determine the volume of material that needs to be excavated and dumped. Another use is to identify areas of sediment erosion and deposition in a river valley.
