Apportion Polygon (Analysis Tools)
Summary
Summarizes the attributes of an input polygon layer based on the spatial overlay of a target polygon layer and assigns the summarized attributes to the target polygons. The target polygons have summed numeric attributes derived from the input polygons that each target overlaps. This process is typically known as apportioning or apportionment.
This tool can be used to estimate the population of one feature based on the percentage of that feature that overlays another feature with a known population.
  • The Enrich Layer tool uses detailed aggregation and apportionment settings to summarize data.
  • The Apportion Polygon tool is similar to the Enrich Layer tool. However, Apportion Polygon uses specified apportionment, while Enrich Layer uses U.S. Census Block points or global settlement points for apportionment. For more information, see Data apportionment.
Illustration
Apportion Polygon tool illustration
The partial sum of input attributes within the target is shown.
Usage
  • By default, the percentage of overlapping area determines the percentage of the attributes transferred. Alternatively, you can use the Estimation Features parameter to create a percentage using the proportion of points or length of the line.
  • The Sum statistic is the default statistic for apportioning attributes. The Sum statistic is only suitable for apportioning count-based attributes such as population. The Mean and Median statistics are available when the Apportion Method parameter is set to Area and are suitable for apportioning rate-based attributes, such as population percentages.
    A weight field from the input polygon will be normalized and used to adjust how much the attributes are transferred. A weight field of 0 will set the apportioned attributes from the input to the targets to 0.
  • If specified, the Estimation Features parameter value is used to determine how attributes will be transferred, instead of using the area. The estimation features must intersect the Input Polygons parameter value to be counted. If the estimation features also intersect the Target Polygons parameter value, the attributes will be transferred to the target from the input feature.
  • The Maintain target geometry parameter is used to include either the target geometry or the intersection of the input and target geometries in the output geometry.
  • This tool honors the Parallel Processing Factor environment. If the environment is not set (the default) or is set to 100, full parallel processing will be enabled and the tool will attempt to distribute the work to all the logical cores on the machine. Setting the environment to 0 will disable parallel processing. Specifying a factor between 1 and 99 will cause the tool to identify the percentage of logical cores to use by applying the formula (Parallel Processing Factor / 100 * Logical Cores) rounded up to the nearest integer. If the result of this formula is 0 or 1, parallel processing will not be enabled.
Parameters
Label Explanation Data type
Input Polygons
The polygon features with numeric attributes that will be summarized into the target polygon geometries.
Feature Layer
Fields to Apportion
The numeric fields from the input polygons that will be summarized by each target polygon and recorded in the output feature class.
Value table columns:
  • Apportion Field—The apportioned field attribute values that will be used to calculate the specified statistic.
  • Statistic Method—The statistic method that will be used on the apportioned values.
    • Sum—The values for the specified field will be added together. Use this statistic for count-based attributes. This is the default.
    • Mean—The average for the specified field will be calculated. Use this statistic for rate-based attributes, such as population percentages. This option is only valid when the Apportion Method parameter is set to Area.
    • Median—The median of the specified field will be calculated. Use this statistic for rate-based attributes, such as population percentages. This option is only valid when the Apportion Method parameter is set to Area.
Value Table
Target Polygons
The polygon features and their apportioned fields that will be copied to the output feature class.
Feature Layer
Output Feature Class
The output feature class containing the attribute and geometries of the target polygons as well as the specified apportion fields from the input polygons.
Feature Class
Apportion Method
Specifies the method that will be used to apportion the fields from the input polygons to the target polygons.
  • Area—The amount that each input polygon contributes to the summarized values for each target feature will be determined by the area of overlap between the two features. If an input feature overlaps two target features by the same amount, the apportioned fields will be divided in two and contribute to both target features by half of the total value. This is the default.
  • Length—The attributes from the input features will be divided based on the percentage of how much of a line is within each target feature. Only the line intersecting the input feature is included in the calculation. The line outside the input feature is excluded. For example, if one target feature covers 750 meters of a line, and another target feature covers 250 meters of a line, 75% (750 / 1000) of the input feature's attribute values will be aggregated to the first target feature, and 25% (250 / 1000) of the input feature's attribute values will be aggregated to the second target feature.
  • Points—The attributes from the input features will be divided based on the number of points inside each target feature overlapping an input feature. Points outside of the input feature are excluded. Optionally, a weight field can be specified so that the total weight of all points within each target feature will be used to determine how the input features' attribute values are divided. For example, if two target features overlap one input feature, and there are two points inside the first target feature and eight points inside the second target feature, 20% (2 / 10) of the input feature's attribute values will be aggregated to the first target feature, and 80% (8 / 10) of the input feature's attribute values will be aggregated to the second target feature.
String
Estimation Features
(Optional)
The input point or polyline features that will be used to estimate the percent of the input polygon apportion fields to apportion to the target polygon. This is the amount of the point or line within the intersection divided by the amount within the input feature to create a percentage.
Feature Layer
Weight Field
(Optional)
A numeric field from the target polygon layer that will be used to adjust which target polygons receive larger apportioned values from the input polygons' fields to apportion. Targets with higher weight are apportioned a higher ratio of the field values.
If estimation features are specified, the weight field will be a numeric field from the estimation features that will adjust the values apportioned to the target polygons intersecting the estimation features.
Field
(Optional)
Specifies whether the output feature class will maintain the original geometries of the target polygon layer.
  • Checked—The output feature class will maintain the original geometries of the target polygon layer. This is the default.
  • Unchecked—The output feature class will be a geometric intersection of the target polygons and the input polygons. Only areas of the target polygons that overlap an input polygon will be included in the output.
Boolean
Environments
Current Workspace, Scratch Workspace, Output Coordinate System, Extent, Parallel Processing Factor
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
