Assign Weights By Pairwise Comparison (Analysis Tools)
Summary
Calculates the relative weights for a set of input variables by comparing them in pairs.
Learn more about how Assign Weights By Pairwise Comparison works
Usage
This tool creates pairs from the input variables. Rank each pair by identifying the variable that is more important and by how much. The tool creates a comparison matrix from the rankings of the pairs. The relative weights for each variable is calculated from the matrix.
The Input Variables to Compare parameter value can be any names you provide. These names can represent raster or feature layer names, field names, or other variables to compare. The minimum number of variables is two and the maximum is nine.
There are some differences when using the tool in the Geoprocessing pane compared to Python. In the Geoprocessing pane, the pairs are created from the Input Variables to Compare parameter values. Click the Compare variables and calculate weights button to open the Pairwise Comparison Matrix window. The window displays the variable pairs along with a slider accompanying each pair. Adjust the sliders to specify which variable for each pairing is more important and by how much. As the sliders are moved, the comparison matrix is updated.
The comparisons are made using a 1 to 9 scale developed by Thomas Saaty (Saaty, 2008). The scale, their definitions, and explanations of each value in the scale as presented by Saaty are identified in the table below.
Intensity of Importance
Definition
Explanation
Equal importance
Two activities contribute equally to the objective.
Weak or slight
Moderate importance
Experience and judgement slightly favor one activity over the another.
Moderate plus
Strong importance
Experience and judgement strongly favor one activity over another.
6
Strong plus
7
Very strong or demonstrated importance
An activity is favored very strongly over another; its dominance is demonstrated in practice.
8
Very, very strong
9
Extreme importance
The evidence favoring one activity over another is of the highest possible order of affirmation.
The values in the scale are multipliers. In a pairwise comparison, if one variable is twice as important as the other, move the slider to 2 toward the more important variable. However, this does not mean that the final weight for the variable will be twice as much as the other. The multiplier only applies to that pairwise comparison.
The Pairwise Comparison Matrix parameter control uses two interacting tables to create the comparison matrix. When a slider is moved, a comparison is made, the values in the Comparison Matrix table are updated, and the weights are recalculated. By default, all comparison evaluations are set to 1.
Move the slider close to the desired evaluation and refine the comparison by clicking the slider bar to reach the specific value. The sliders increment by tenths when clicked.
In Python, you can create a file or table using a table or text editor (or from a previous run of the tool) and enter the resulting file as the
comparison_matrixparameter value.Valid file formats for the
comparison_matrixvalue include geodatabase table, dBASE (.dbffile), and comma-delimited files (.csvand.txt).The following is an example of a comparison matrix without weights created using a table editor:
Variables
Dist_Roads
Elevation
Landuse
Aspect
Dist_Roads
Elevation
Landuse
0.333
Aspect
0.143
See Input comparison matrix formats for more examples of acceptable comparison matrices with and without weights.
Verify the consistency of the pair evaluations by clicking the Consistency button below the Comparison Matrix in the Pairwise Comparison Matrix window. The consistency ratio (CR) will be displayed below the Comparison Matrix. The CR should be below 0.1.
If the CR is above 0.1, the CR value and the top three pairs that are most inconsistent will be highlighted in red. The evaluations for the inconsistent pairs can be adjusted to improve the consistency of the comparisons.
In Python, the variables are specified using the
input_variablesparameter. The pairwise comparisons are identified in thecomparison_matrixparameter. The pairs and the evaluations for the comparisons can be directly specified. Alternatively, any file containing a valid comparison matrix created from a table or text editor (or an output table from the tool) can be entered.See Input comparison matrix formats for valid input comparison matrices.
The Output Table parameter value contains the calculated weights for the input variables and optionally includes the pairwise comparison matrix.
Valid output table types are geodatabase table, dBASE (
.dbf), and comma-delimited files (.csvand.txt). By default, the output table will be a geodatabase table in a workspace. When the output table is in a file workspace, the output table will be a dBASE table by default.The following is an example of an output table when the Add comparison matrix to output parameter is checked.
Variables
Dist_Roads
Elevation
Landuse
Aspect
Weights
Dist_Roads
Elevation
Landuse
0.333
0.407
Aspect
0.143
For more examples of output tables formats with and without weights, see Output table formats.
The Add comparison matrix to output parameter identifies whether the output table is saved with or without the comparison matrix. When checked (
ADD_MATRIXin Python), the output table will contain both the pairwise comparison matrix and the calculated weights.
Parameters
| Label | Explanation | Data type |
Input Variables To Compare |
The variable names that will be compared. Any name can be provided. The minimum number of variables is two and the maximum is nine. |
String |
Output Table |
The name of the output table that will contain calculated weights for the input variables. When the Add comparison matrix to output parameter is checked, the output table will also include the pairwise comparison matrix. |
Table |
Add comparison matrix to output (Optional) |
Specifies whether the Output Table parameter value will contain the pairwise comparison matrix.
Boolean |
Pairwise Comparison Matrix (Optional) |
The pairwise comparison matrix that will be used when calculating the weights. Use the sliders in the Pairwise Comparison Matrix window to identify which variable in each pairwise comparison is more important and by how much. |
Pairwise Weights Table |
Environments
Current Workspace, Scratch Workspace
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
References
See the following references for additional information:
- Saaty, T. L. 2008. "Decision making with the analytic hierarchy process". International Journal of Services Sciences, 1(1), 83-98.
