Split By Attributes (Analysis Tools)
Summary
Splits an input dataset by unique attributes.
Usage
  • A feature class or table will be created for every unique combination of attributes from the Split Fields parameter value.
Parameters
Label Explanation Data type
Input Table or Features
The input feature class or table containing the data that will be split into the target workspace.
Table View
Target Workspace
The existing workspace where the output feature classes or tables will be written.
Workspace; Feature Dataset
Split Fields
The fields on which the input will be split into new feature classes or tables.
Field
Derived output
Update Target Workspace
The workspace containing the features classes or tables created by splitting the input.
Environments
Current Workspace, Scratch Workspace, Default Output Z Value, M Resolution, M Tolerance, Output CONFIG Keyword, Output M Domain, Output XY Domain, Output Coordinate System, Extent, Output has M values, Output has Z values, XY Resolution, XY Tolerance
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
