Table Select (Analysis Tools)
Summary
Selects table records matching a Structured Query Language (SQL) expression and writes them to an output table.
Usage
The input can be a dBASE, or geodatabase table, a feature class, table view, or VPF dataset.
The Expression parameter value can be created with the Query Builder or simply typed in. For details on the expression syntax, see SQL reference for query expressions used in ArcGIS or Introduction to query expressions.
If a table view is used for Input Table and no expression is entered, only the selected records are written to the output table. If a table view is used for input table and an expression is entered, the expression is only executed against the selected records, and the expression-based subset of the selected set is written to the output table.
To create a table from the table view's selected set of records, use the Copy Rows tool.
Parameters
| Label | Explanation | Data type |
Input Table |
The table containing records matching the specified expression that will be written to the output table. |
Table View; Raster Layer |
Output Table |
The output table containing records from the input table that match the specified expression. |
Table |
Expression (Optional) |
An SQL expression used to select a subset of records. For more information on SQL syntax, see Introduction to query expressions. |
SQL Expression |
Environments
Output CONFIG Keyword, Current Workspace, Scratch Workspace
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
