Geoprocessing considerations for elevation surface input
Elevation surfaces define height values across the extent of a map or scene. The most common uses for elevation surfaces are to define the elevation source for rasterized content and on-ground vector symbols and to define heights or z-values when editing features. You can also use elevation surfaces as input to geoprocessing tools that support those surface datasets.
Each elevation surface can have one or more elevation data sources that define the height across the surface. The following table lists the supported elevation sources:
Supported elevation source |
Data location |
Raster dataset |
File on disk |
TIN dataset |
File on disk |
Web elevation layer |
Portal item |
Web imagery layer |
Portal item |
Cached elevation image service |
ArcGIS Server service |
Select an elevation surface as input
If the map or scene has an elevation surface, most geoprocessing tools that accept elevation datasets can also use the elevation surface as input. To use the elevation surface as input, select the name of the elevation surface from the drop-down list of layers for the input parameter.
After selecting the elevation surface by name, the value in the parameter text box will be transformed into the path to the source dataset that the elevation surface represents.
Usage notes
Using an elevation surface as input to a geoprocessing tool is essentially a shortcut to selecting the data that is used as the elevation surface source. Properties or settings that are applied to an elevation surface do not apply to the geoprocessing operation. This is why, after selecting the elevation surface name, the parameter value changes to the elevation surface source data path, so the exact data that is being used as input to the geoprocessing tool is understood.
When you use a large portal or server-based elevation surface such as the default World Elevation 3D surface as input, performance will be significantly slower than if you use an elevation surface with a local data source. Some tools may not complete successfully due to attempting to load the entire service into memory. Using service-based elevation surfaces will work best if you apply the Extent environment to limit the processing to as small an area as necessary for the analysis.
Use the Make Image Server Layer tool to create a layer that can be used as input to tools that accept raster layers. This tool allows you to specify an extent, cell size, and other important settings to perform analysis using an image service that are not possible by selecting the elevation surface as input as described above.
