Append Data (GeoAnalytics Server Tools)
Summary
Appends features to an existing hosted feature layer.
Legacy:
The ArcGIS GeoAnalytics Server extension is being deprecated in ArcGIS Enterprise. The final release of GeoAnalytics Server was included with ArcGIS Enterprise 11.3. This geoprocessing tool is available through ArcGIS Enterprise 11.3 and earlier versions.
Illustration
Append Data tool illustration
Append Data workflow
Usage
  • This geoprocessing tool is available with ArcGIS Enterprise 10.6.1 or later.
  • The Input Layer parameter value must be an existing hosted point, line, polygon, or table layer. To append to a different layer, you must create a hosted layer of that dataset first. To do this, use the Copy To Data Store tool, or share a layer to your portal. To learn more about sharing layers, see Introduction to sharing web layers.
  • The Append Layer parameter value can be a point, line, polygon, or table big data file share dataset or feature layer.
  • The Append Layer value must have the same geometry type as the Input Layer value. For example, append table features to table features, and point features to point features. No features will be appended if the geometry types are not the same.
  • The Append Layer value must have the same time type as the Input Layer value. These types include instant, interval, or none.
  • The fields, geometry, and time of the Input Layer value will not be modified.
  • The following two methods can be used to append features:
    • Append matching fields only—Only fields with matching names and types will be appended. This is the default.
    • Append matching fields and resolve differences—Use the Append Fields or Append Expressions parameters to match fields with different names or to calculate values for specified fields.
      Learn more about Append Data expressions
  • Any Append Layer fields that are not matched in the Append Fields or Append Expressions parameters will be excluded from the appended results.
    For example, human migration researchers want to append datasets with the input layer and append layer schemas seen below. Both layers have the Country field of type text in common, and both have two additional fields with the same data type but unique names. The input layer has Pop_ and Pop_Density fields, and the append layer has Population and area_km2 fields. The researchers want to match the Country field to the Country field, append the Population field to the Pop_ field, and calculate the population density for the Pop_Density field using a mathematical calculation.
    Input layer schema and append layer schema examples
    Input layer and append layer example schemas to be used in the Append Data tool
    By default, Append Data will match Country fields because they have the same field name and field type. By default, the Pop_ and Pop_Density fields have no match in the append layer and will be appended with null values.
    Default field mapping example
    Default field mapping that will be applied when the Append matching fields only option is selected for the Append Method parameter.
    Select the Append matching fields and resolve differences option for the Append Method parameter to define custom field mapping specifications. Use the Append Fields parameter to append the Input Field Pop_ field with values from the Append Field Population field. Use the Append Expressions parameter to calculate Pop_Density values for the appending features using the Population and area_km2 append layer fields by building the following Arcade expression: $feature["Population"]/$feature["area_km2"].
    Defined field mapping example
    Defined field mapping as specified in the Append Fields and Append Expressions parameters.
  • This geoprocessing tool is powered by ArcGIS GeoAnalytics Server. Analysis is completed on GeoAnalytics Server, and results are stored in your content in ArcGIS Enterprise.
  • When running GeoAnalytics Server tools, the analysis is completed on GeoAnalytics Server. For optimal performance, make data available to GeoAnalytics Server through feature layers hosted on your ArcGIS Enterprise portal or through big data file shares. Data that is not local to GeoAnalytics Server will be moved to GeoAnalytics Server before analysis begins. This means that it will take longer to run a tool and, in some cases, moving the data from ArcGIS Pro to GeoAnalytics Server may fail. The threshold for failure depends on your network speeds, as well as the size and complexity of the data. It is recommended that you always share your data or create a big data file share.
    Learn more about sharing data to your portal
    Learn more about creating a big data file share through Server Manager
Parameters
Label Explanation Data type
Input Layer
The hosted feature layer to which features will be appended.
Record Set
Append Layer
The layer containing features that will be appended to the input layer.
Record Set
Append Method
Specifies how fields from the input layer will be appended with values from the append layer.
  • Append matching fields only—Input layer fields will only be appended if they have a matching field in the append layer. Fields without a match will be appended with null values.
  • Append matching fields and resolve differences—Input layer fields can be appended with append layer fields of the same name and different type or with values calculated from Arcade expressions.
String
Append Fields
(Optional)
The append layer fields of the same type and different name as the input layer fields that will be appended. Select the input field to append to, and the append field containing the values to append.
Value table columns:
  • Input Field—The input layer field to match with an append layer field.
  • Append Field—The append layer field to match with an input layer field.
Value Table
Append Expressions
(Optional)
The Arcade expression that will be used to calculate field values for the input field. Expressions are written in Arcade and can include mathematical operators and multiple fields.
Select the fields to append to, and provide an expression for each to calculate the values to append. If the layer is added to the map, the fields and helpers can be used to build an expression.
  • Input Field—The input layer field to append with the calculated Arcade expression values.
  • Expression—The Arcade expression that will be used to calculate field values for the input field.
Value Table
Derived output
Append Result
The updated input to which features have been appended.
Record Set
Environments
Extent, Current Workspace
Licensing information
  • Basic: Requires ArcGIS GeoAnalytics Server
    Available with ArcGIS Enterprise 10.6.1
  • Standard: Requires ArcGIS GeoAnalytics Server
  • Advanced: Requires ArcGIS GeoAnalytics Server
