An overview of the Manage Data toolset
The Manage Data toolset contains tools used for the day-to-day management of geographic data.
This toolset uses distributed processing to complete analytics on your GeoAnalytics Server.
Legacy:
ArcGIS GeoAnalytics Server is being deprecated in ArcGIS Enterprise. The final release of GeoAnalytics Server was included with ArcGIS Enterprise 11.3.
These tools are available through ArcGIS Enterprise 11.3 and earlier versions when you have an active ArcGIS Enterprise portal that has GeoAnalytics Server configured for the Feature Analysis - GeoAnalytics Tools setting. To access and run the tools, you must have spatial analysis privileges.
These tools can be accessed from either the Analysis ribbon or the Portal tab in the Geoprocessing pane.
Learn more about portal tools
Tool
Append Data
Appends features to an existing hosted feature layer.
Calculate Field
Creates a layer with calculated field values.
Clip Layer
Extracts input features from within specified polygons.
Copy To Data Store
Copies features from the input to a new feature service in your portal.
Dissolve Boundaries
Finds polygons that intersect or have the same field values and merges them to form a single polygon.
Merge Layers
Combines feature layers to create a single output layer.
Overlay Layers
Overlays the geometries from multiple layers into a single layer. Overlay can be used to combine, erase, modify, or update spatial features.
