Join Features expressions
The Join Features tool uses ArcGIS Arcade expressions to specify join conditions. In some cases, you may want to specify a condition to select features that should be included in the join. You can perform simple join conditions (such as field a > field c) as well as advanced conditions. The conditions are tested on each feature to determine what is analyzed. Calculations are performed when the analysis runs on ArcGIS GeoAnalytics Server.
At ArcGIS Enterprise 10.6 and later, expressions are formatted using Arcade. In Arcade, field names in Join Features are formatted as $target["field name"] and $join["field name"] or $target.fieldname and $join.fieldname. The first option, $target["field name"] and $join["field name"], is required when a field name includes a space. All examples below use this option.
Join Features requires two inputs, a target layer and a join layer. Accordingly, any Arcade expression in Join Features must outline the dataset being used. For example, an operation to calculate whether a field in the target layer named field1 is greater than a field in the join layer named field2 would be expressed as $target["field1"] > $join["field2"]. This is different from expressions in other GeoAnalytics Tools, which use the format $feature["fieldname"].
Learn more about Arcade expressions
The following tools use Arcade expressions in GeoAnalytics Server:
Legacy:
The ArcGIS GeoAnalytics Server extension is being deprecated in ArcGIS Enterprise. The final release of GeoAnalytics Server was included with ArcGIS Enterprise 11.3. These tools are available through ArcGIS Enterprise 11.3 and earlier versions.
Mathematical operator and function examples
Expressions can mathematically process numbers. The following table shows examples of available operations:
Learn more about mathematical operations and functions in Arcade
Operator
Explanation
Example
Result
a + b
a plus b.
fieldname contains a value of 1.5
$target["fieldname"] + 2.5
4.0
a - b
a minus b.
fieldname contains a value of 3.3
$target["fieldname"]- 2.2
1.1
a * b
a times b.
fieldname contains a value of 2.0
$join["fieldname"] * 2.2
4.4
a / b
a divided by b.
fieldname contains a value of 4.0
$join["fieldname"] / 1.25
3.2
abs( a )
Returns the absolute (positive) value of a.
fieldname contains a value of -1.5
abs($target["fieldname"])
1.5
log( a )
Returns the natural logarithm (base E) of a.
log($join["fieldname"])
sin( a )
Returns the trigonometric sine of a. The input is assumed to be an angle in radians.
fieldname contains a value of 1.5707
sin($target["fieldname"])
cos( a )
Returns the trigonometric cosine of a. The input is assumed to be an angle in radians.
fieldname contains a value of 0
cos($join["fieldname"])
tan( a )
Returns the tangent of a. The input is assumed to be an angle in radians.
tan($target["fieldname"])
sqrt( a )
Returns the square root of a.
fieldname contains a value of 9
sqrt($join["fieldname"])
min( a, b )
Returns the lowest-valued number between a and b.
fieldname contains a value of 1.5 and a value of -3
min($join["fieldname"], -3)
-3
max( a, b )
Returns the highest-valued number between a and b.
fieldname1 contains a value of 1.5, and fieldname2 contains a value of -3
max($target["fieldname1"], $join["fieldname2"])
1.5
constrain(<value>,<low>,<high>)
Returns the input value if it's within the constraining bounds. If the input value is less than the low value, it returns the low value. If the input value is greater than the high value, it returns the high value.
constrain($target["distance"], 0, 10)
constrain($join['Store dist'], 6, distance)
Returns 0 if distance is less than 0, 10 if distance is greater than 10, and distance otherwise.
Returns 6 if Store dist is less than 6, distance if Store dist is greater than distance, and Store dist otherwise.
Multiplication example for a join condition expression using a field from the target dataset.
$target["Distance"] * 2 > $join["DistField"]
Text function examples
Join condition expressions can process text. The following table shows examples of available operations:
Learn more about text functions in Arcade
Operator
Explanation
Example
Result
concatenate( <values>, <separator>)
Concatenates values together and returns a string.
  • values—An array of string values to concatenate.
  • separator (optional)—A separator to use for concatenation if the values parameter is an array, or a string to concatenate if a single value is provided for the first parameter. If not provided, it will be empty.
fieldname contains a value of GeoAnalytics
Concatenate ([$target["fieldname"], "is", "great!"], ' ')
GeoAnalytics is great!
find(<searchText>, <text>, <startPos>)
Finds a string within a string. Wildcards are not supported.
  • searchText—The substring to search for.
  • text—The text to search.
  • startPos (optional)—The zero-based index of the location in the string to search from.
fieldname1 contains a value of 14NorthStreet and fieldname2 contains a value of North
find($target["fieldname2"], $join["fieldname1"])
lower(<value>)
Makes a string lowercase.
  • value—The string to be made lowercase.
fieldname contains a value of GEOANALYTICS
lower($join["fieldname"])
geoanalytics
Text example using find and lower.
find(("north"), lower("146NorthStreet")) == False
Date function examples
Join expressions can process dates. The table below shows examples of available operations.
Learn more about date functions in Arcade
In Arcade, month values range from 0 (January) to 11 (December), day values from 1 to 31, hour values from 0 (12:00 a.m.) to 23 (11:00 p.m.), minute and second values from 0 to 59, and millisecond values from 0 to 999. Arcade dates return time values for the GeoAnalytics Server location.
Operator
Explanation
Example
Result
date(<value>, <month>, <day>, <hour>, <minute>)
Parses a value or set of values into a date string.
  • value (optional)— Either the number of milliseconds since January 1, 1970, UTC or a number representing a year. If a year is specified, the month and day must also be provided in subsequent parameters. This value can also be a date string or an ISO 8601 string to be converted to a date.
  • month (optional)—The month (0–11), where 0 is January and 11 is December.
  • day (optional)—The day of the month (1–31).
  • hour (optional)—The hour of the day (0–23).
  • minute (optional)—The minute of the hour (0–59).
  • second (optional)—The second of the minute (0–59).
  • millisecond (optional)—The millisecond of the second (0–999).
fieldname contains a value of 1476987783555
Example 1: Date($target["fieldname"])
Example 2: Date(2017,0,14,0)
Example 3: Date()
Example 1: 20 Oct 2016 11:23:03 am
Example 2: 14 Jan 2017 12:00:00 am
Example 3: Returns the current time
DateDiff(<date1>, <date2>, <units>)
Subtracts two dates and returns the difference in the specified units.
  • date1—The date value from which to subtract a second date.
  • date2—The date value to subtract from the first given date.
  • units (optional)—The units used to return the difference of the two given dates. The supported unit types are milliseconds, seconds, minutes, hours, days, months, and years. The default value is milliseconds.
Example 1: DateDiff(Date(2017,1,14,0), Date())
Example 2: DateDiff(Date(2017,1,14,0), Date(), "Years")
Result will vary depending on when you run this command.
Example 1: -20532129137
Example 2: -0.6546783768647119
Year(<dateValue>)
Returns the year of the given date
  • value—A date value identifying the year.
Example 1: fieldname is a field of type Date with a value of value of 09 Oct 2017 04:30:43 pm
Year($join["fieldname"])
Example 2: fieldname is a string field formatted as an ISO 8601 string with a value of 2012-09-27
Example 2: fieldname is a string field formatted as an ISO 8601 string with a value of Year(Date($target["fieldname"]))
Example 1: 2017
Example 2: 2012
Conditional operators
Conditional statements can use the following operators:
Operator
Explanation
Example
Results
a > b
a < b
a is greater than b
a is less than b
10 > 2
False
a >= b
a <= b
a is greater than or equal to b
a is less than or equal to b
abs(-10) >= 10
True
a != b
a is not equal to b
abs(-3) != -3
True
a == b
a is equal to b
abs(-5) == 5
True
<condition1> || <condition2>
Condition 1 or condition 2 is met.
(abs(-5) == 5) || (10 < 2)
True
<condition1> && <condition2>
Condition 1 and condition 2 are met.
(abs(-5) == 5) && (10 < 2)
False
Logical operator examples
In addition to the conditional operators, more advanced logical operators, shown in the following table, can be used to join features:
Learn more about logical functions in Arcade
Function
Explanation
Example
Result
constrain( $target["distance"], 0, 10)
iif(<condition>,<true value>,<false value>)
Returns one value if a condition evaluates to true and returns another value if the condition evaluates to false.
<true value> and <false value> can be the following:
  • A numeric field. If there is a space in the field name, use square brackets.
  • A number.
  • A function.
iif($target["field1"] > $join["field2"], $join["field1"], 0)
iif($target["field1"] > $join["field2"], iif($target["field2"] = 0, $join["field3"], $target["field4"]), 0)
Returns field1 if field1 is greater than field2, and 0 otherwise.
Returns the result of the second iif function if field1 is greater than field2, and 0 otherwise.
when(<expression1> , <result1> , <expression2> , <result2> , ... , <expressionN> , <resultN>, <default>)
Evaluates a series of expressions in order until one evaluates to true.
  • expression—An expression.
  • result—The result of the expression. It can be a number or field.
  • default—An optional value if none of the expressions match.
when(($target["field1"] + 10) > 1, 1,($join["field2"] + 10) > 2 , 2, $target["field3"])
If field1 + 10 is greater than 1, it returns 1. If not, it checks if field2 + 10 is greater than 2. If it is, it returns 2. If not, it returns field3.
decode(<conditional val> , <case1> , <result1>, <case2>, <result2>, ... <caseN>, <resultN>, <defaultValue> )
Evaluates an expression and compares its value with subsequent parameters. If the expression matches, it returns the next parameter value. If none match, there is the option for the last parameter to be a default return value.
  • conditional val—A conditional value. It can be a field or an expression.
  • case—A value to be compared to the conditional val.
  • result—The result if the corresponding case matches the conditional val.
  • defaultValue—An optional value if no other values are true.
decode($target["field1"] + 3 , $join["field1"], 1, $target["field2"], 2, 0)
Compares equality between the conditional val field1 + 3 and case1 field1. If true, it returns 1. If false, it compares the equality between field1 + 3 and field2. If true, it returns 2; otherwise, it returns 0.
